jQuery UI Widgets Forums Layouts Docking Height problem in docking
This topic contains 2 replies, has 2 voices, and was last updated by  aravindtrue 12 years, 6 months ago.
  • Height problem in docking #7929
    aravindtrue
    Please have a look at this http://jsfiddle.net/sqvRL/28/
    The problem is, the height of second window ‘CSIC’ is fixed and creates the scrollbar when the content exceeds the height.
    I am facing this problem, when I prefix or traverse with ‘#sample’ in css. Whereas the scrollbar goes off, if I remove the #sample from the CSS.
    Also, the first window ‘database management system’ always has the scrollbar. Why it is behaving so?
    I need all the window to be auto height. How can I achieve this?
    Please help he on this.
    Aravind
    Height problem in docking #7930
    Hi Aravind,
    To change the window’s height/width, you need to set it to a value in pixels. It does not support auto height.
    Example:
           <div id="window0">
    <div>CISC</div>
    <div>
    <ul style="height: 200px;">
    <li><a href="#">Lorem ipsum</a></li>
    <li><a href="#">Dummy text</a></li>
    <li><a href="#">Lorem ipsum is a dummy text</a></li>
    </ul>
    Height problem in docking #7955
    aravindtrue
    Thank you… 🙂
    Aravind
