jQuery UI Widgets Forums Grid Grouping is not working when virtual mode = true
This topic contains 6 replies, has 4 voices, and was last updated by  Centerbase 9 years, 9 months ago.
  • senthilkumar
    My application Grid enable paging with virtual mode is true property, when doing grouping on first page (page 1) all numeric and alpha numeric columns are grouping fine, when grouping on second page on words(page 2, 3,4 etc..) if grouping numeric columns it shows grouped records fine but if grouping alpha numeric columns it shows empty rows. let me know the issue
    Hello senthilkumar,
    Please make sure you are using the latest version of jQWidgets (3.6.0). Here is an example that shows that this functionality is working: http://www.jqwidgets.com/community/topic/virtual-paging-and-grouping/#post-61922.
    senthilkumar
    one level of grouping is working fine (all numeric and alpha numeric columns) when doing two level of grouping other than first page
    Numeric column + Numeric column = working
    Numeric column + Alpha numeric column = working
    Alpha numeric + Alpha numeric = Not working it shows empty rows
    Result grid
    Hi senthilkumar,
    With the latest version (3.7.0), the example requires a little modification (var data = new Array();):
        <script type="text/javascript" src="../../jqwidgets/jqxgrid.grouping.js"></script>
                var firstNames =
                var lastNames =
                var productNames =
                var priceValues =
                // generate sample data.
                var generatedata = function (startindex, endindex) {
                    for (var i = startindex; i < endindex; i++) {
                        var row = {};
                        row["id"] = i;
                        row["price"] = price;
                        row["quantity"] = quantity;
                        data[i] = row;
                    return data;
                    datatype: "array",
                    localdata: {},
                    totalrecords: 1000000
                // load virtual data.
                    var data = generatedata(params.startindex, params.endindex);
                    return data;
                var totalcolumnrenderer = function (row, column, cellvalue) {
                    var cellvalue = $.jqx.dataFormat.formatnumber(cellvalue, 'c2');
                    return '<span style="margin: 6px 3px; font-size: 12px; float: right; font-weight: bold;">' + cellvalue + '</span>';
                $("#jqxgrid").jqxGrid(
                    width: 850,
                    virtualmode: true,
                    groupable: true,
                    ready: function () {
                        $('#jqxgrid').jqxGrid('addgroup', 'firstname');
                        $('#jqxgrid').jqxGrid('addgroup', 'lastname');
                        { text: 'Id', datafield: 'id', width: 50 },
                        { text: 'First Name', datafield: 'firstname', width: 120 },
                        { text: 'Last Name', datafield: 'lastname', width: 120 },
                        { text: 'Quantity', datafield: 'quantity', width: 100, cellsalign: 'right' },
                        { text: 'Unit Price', datafield: 'price', width: 100, cellsalign: 'right', cellsformat: 'c2' },
                        { text: 'Total', datafield: 'total', cellsrenderer: totalcolumnrenderer, cellsalign: 'right' }
            <div id="jqxgrid">
    As you can see, there are no issues when grouping by two string columns. However, while there are no errors thrown, this configuration (virtual paging + grouping) may not be suitable for real scenarios.
    senthilkumar
    Please kindly test above example, clear all existing grouping then move to page number 2, now start grouping first group ‘First Name’ column then ‘Last Name’ column same bug. Two level of grouping is not working in version 3.7 also, please help us.
    Hi senthilkumar,
    Sorry, but we never supported Grouping in Virtual Mode. This cannot work because is Invalid approach. Data which is Loaded on Demand and stored Per Page Only cannot be Grouped. This is invalid scenario which should never be tried and we consider throwing an exception for pointing that out in future versions.
    Centerbase
    Truth be told, I don’t see how Grouping and Paging is ever a viable combination (even if the whole dataset is loaded in memory). However, I am using Virtual Mode without paging (infinite scrolling). It seems to me that the way Virtual Mode and Grouping could be combined is with one main change to the code.
    If you add a function, similar to rendergridrows, called rendergroups (or something like that). It would pass the column IDs that the grid is currently grouping by and expect an array returned detailing the groups and their respective row counts. The main change to rendergrid rows would be that it would assume that the rows are sorted by each of the group columns in turn followed by the sort columns.
    Example: When rendergroups is called, I return Group A with 3 records, Group B with 4 records, and Group C with 2 records. Then when rendergridrows is called, row 0-2 would be in Group A, 3-6 in Group B, and 7-8 in Group C.
    Is this something that you guys have thought of implementing (or already have and I’m just not seeing it)? Does this seem viable to you?
