jQuery UI Widgets Forums Grid Group level backgroud color
This topic contains 3 replies, has 2 voices, and was last updated by  Dimitar 9 years, 11 months ago.
  • Group level backgroud color #72148
    Pietro
    Dear all,
    I have succesfully applied a background color via CSS to the group header rows.
    However I noticed this is applied to header rows at ALL levels.
    Is it maybe possible to apply different settings to different levels ?
    By exploring the html structure i don’t see any class or any structural difference so to distinguish an inner level from the outer, so i think CSS is not the right way.
    Is there eventually a different technique to render groups differently ?
    Thanks in advance.
    Pietro
    Group level backgroud color #72159
    Hello Pietro,
    Here is how to achieve your requirement using groupsrenderer:
        <script type="text/javascript" src="../../jqwidgets/jqxgrid.grouping.js"></script>
                var url = "../sampledata/customers.xml";
                    datatype: "xml",
                        { name: 'CompanyName', map: 'm\\:properties>d\\:CompanyName', type: 'string' },
                        { name: 'ContactName', map: 'm\\:properties>d\\:ContactName', type: 'string' },
                        { name: 'ContactTitle', map: 'm\\:properties>d\\:ContactTitle', type: 'string' },
                        { name: 'City', map: 'm\\:properties>d\\:City', type: 'string' },
                        { name: 'PostalCode', map: 'm\\:properties>d\\:PostalCode', type: 'string' },
                        { name: 'Country', map: 'm\\:properties>d\\:Country', type: 'string' }
                    root: "entry",
                    record: "content",
                    url: url
                // Create jqxGrid
                $("#jqxgrid").jqxGrid(
                    width: 850,
                    groupable: true,
                    closeablegroups: false,
                    groupsexpandedbydefault: true,
                    showgroupsheader: true,
                    showgroupmenuitems: true,
                    groupsrenderer: function (text, group, expanded, data) {
                        var color;
                        switch (data.level) {
                            case 0:
                                color = 'Blue';
                                break;
                            case 1:
                                color = 'Red';
                                break;
                            case 2:
                                color = 'Green';
                                break;
                        return '<div style="width: 100%; height: 100%; background-color: ' + color + '; color: White;">' + text + '</div>';
                      { text: 'Company Name', datafield: 'CompanyName', width: 250 },
                      { text: 'City', datafield: 'City', width: 120 },
                      { text: 'Country', datafield: 'Country' }
                    groups: ['City']
        <div id="jqxgrid">
    Group level backgroud color #72171
    Pietro
    Amazing, thanks Dimitar!
    Is there a way, other than trial and errors, to understand the details of the data passed at the groupsrenderer function ?
    I’m referring to text, group, expanded, data…
    Pietro
    Group level backgroud color #72179
    Hi Pietro,
    You can see what is passed to the groupsrenderer callback function via debugging (in your IDE or your browser’s developer tools).
