jQuery UI Widgets Forums Grid Grid Rendering issues after creation
This topic contains 2 replies, has 2 voices, and was last updated by  rajinder85 8 years, 11 months ago.
  • rajinder85
    Hello JQWidgets Team,
    I am facing issues where once the grid is created the layout of grid become distorted and there is one blank line at the end of grid where scroll bar appears. When i call render method of jqxgrid, the problem fixes and grid then becomes properly aligned but i cannot use this solution due to performance bottlenecks as render is taking similar time as creation of grid.
    I tried refresh function as well but it didn’t helped.
    Can you please provide some solution to this problem ?
    Rajinder
    Hello Rajinder,
    Please make sure you are using the latest version of jQWidgets (4.1.2). If the issue persists, please share a jsEditor example we can test to reproduce it.
    We are looking forward to your reply.
    rajinder85
    Upgrading version to 4.1.2 fixed the issue.
    Thanks much
    Rajinder
