jQuery UI Widgets Forums Grid Grid Number input issue
This topic contains 4 replies, has 2 voices, and was last updated by  ivailo 9 years, 5 months ago.
  • Grid Number input issue #77736
    Dinesh
    Hello
    There seems to be an error when using numberinput with grid and selection mode as ‘multiplecellsadvanced’.
    Click on the cell once and start typing and the first digit just gets disappear.
    http://jsfiddle.net/4e6a7qwc/
    Problem is only on ‘multiplecellsadvanced’ and is because when you start typing the first value gets selected and gets replaced at the time when you type the second number. May be it is a general problem with other components as well.
    Grid Number input issue #77739
    Dinesh
    Sorry! other components work perfectly..It is only the issue with number input.
    Grid Number input issue #77749
    ivailo
    Hi Dinesh,
    To avoid this behavior set editmode: 'click',.
    Ivailo Ivanov
    Grid Number input issue #77752
    Dinesh
    Hi Ivalio,
    Thanks for the reply.
    If I use editmode: ‘click’, my multiplecellsadvanced is lost.
    I need multiselection because user selects multiple cells and use clipboard to paste values at a stretch.
    Dinesh
    Grid Number input issue #77850
    ivailo
    Hi Dinesh,
    We will consider this behavior.
    Like a workaround you can use the default editor and validate the input.
    Ivailo Ivanov
