jQuery UI Widgets Forums Grid Grid localization issue
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 10 years, 6 months ago.
  • Grid localization issue #59774
    DaTe
    there is an issue when the decimal and thousand separator are localized. Please find below the code. If you try to insert in the “qt.” field a value like 123,45 the cell will be rendered as 123..45 !
    Here is the code:
    var data = generatedata(250);
     var source = {
         localdata: data,
         datafields: [{
             type: 'string'
             type: 'string'
             type: 'bool'
             type: 'date'
             type: 'number'
             type: 'number'
         datatype: "array"
     var getLocalization = function () {
         var localizationobj = {};
         localizationobj.pagergotopagestring = "Gehe zu:";
         localizationobj.pagershowrowsstring = "Zeige Zeile:";
         localizationobj.pagerrangestring = " von ";
         localizationobj.pagernextbuttonstring = "voriger";
         localizationobj.pagerpreviousbuttonstring = "nächster";
         localizationobj.sortascendingstring = "Sortiere aufsteigend";
         localizationobj.sortdescendingstring = "Sortiere absteigend";
         localizationobj.sortremovestring = "Entferne Sortierung";
         localizationobj.firstDay = 1;
         localizationobj.percentsymbol = "%";
         localizationobj.currencysymbol = "€";
         localizationobj.currencysymbolposition = "after";
         localizationobj.decimalseparator = ",";
         localizationobj.thousandsseparator = ".";
         var days = {
             // full day names
             names: ["Sonntag", "Montag", "Dienstag", "Mittwoch", "Donnerstag", "Freitag", "Samstag"],
             // abbreviated day names
             namesAbbr: ["Sonn", "Mon", "Dien", "Mitt", "Donn", "Fre", "Sams"],
             // shortest day names
             namesShort: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"]
         localizationobj.days = days;
         var months = {
             // full month names (13 months for lunar calendards -- 13th month should be "" if not lunar)
             names: ["Januar", "Februar", "März", "April", "Mai", "Juni", "Juli", "August", "September", "Oktober", "November", "Dezember", ""],
             // abbreviated month names
             namesAbbr: ["Jan", "Feb", "Mär", "Apr", "Mai", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dez", ""]
         var patterns = {
             d: "dd.MM.yyyy",
             D: "dddd, d. MMMM yyyy",
             t: "HH:mm",
             T: "HH:mm:ss",
             f: "dddd, d. MMMM yyyy HH:mm",
             F: "dddd, d. MMMM yyyy HH:mm:ss",
             M: "dd MMMM",
             Y: "MMMM yyyy"
         localizationobj.patterns = patterns;
         localizationobj.months = months;
         localizationobj.todaystring = "Heute";
         localizationobj.clearstring = "Löschen";
         return localizationobj;
     $("#jqxgrid").jqxGrid({
         width: 700,
         showfilterrow: true,
         selectionmode: 'singlecell',
         columns: [{
             text: 'Name',
             columntype: 'textbox',
             filtertype: 'textbox',
             datafield: 'name',
             width: 115
             text: 'Produkt',
             datafield: 'productname',
             width: 220
             text: 'Datum',
             datafield: 'date',
             columntype: 'datetimeinput',
             filtertype: 'date',
             width: 210,
             cellsalign: 'right',
             cellsformat: 'd'
             text: 'Qt.',
             datafield: 'quantity',
             cellsformat: "f",
             //columntype: 'numberinput',
             //filtertype: 'textbox',
             //cellsalign: 'right',
             width: 100
             text: 'Preis',
             datafield: 'price',
             cellsformat: "c2",
             cellsalign: 'right'
    DaTe
    Grid localization issue #59797
    Hi DaTe,
    You can use “f2” format as a solution, insted of “f” format.
