jQuery UI Widgets Forums Grid Grid in virtual mode calls server-side script twice
This topic contains 5 replies, has 3 voices, and was last updated by  ngc2 7 years, 2 months ago.
  • Dan Fad
    hello,
    i have a grid in virtual mode. i set the grid in a two step process.
    first step is setting the grid columns.
    second step is loading data on a click of a button.
    the problem is that the server-side script is called twice: during setting of the grid source ( source:dataAdapter ) and again when rendergridrows function returns dataAdapter.records.
    here is the sample code:
    var theme=getTheme();
    /*first step is setting the grid coulmns*/
    $("#jqxgrid").jqxGrid({
    altrows: true,
    theme:theme,
    pagesize: 20,
    { text: 'Lastname', datafield: 'col1', width: 150},
    { text: 'Firstname', datafield: 'col2', width: 150 },
    { text: 'Birthdate', datafield: 'col3', width: 100 }
    /*second step is loading data on click of a button*/
    $("#btnLoad").jqxButton({ width: '160', theme: theme});
    $("#btnLoad").on('click', function () {
    var source ={
    { name: 'col1'},
    { name: 'col2'},
    { name: 'col3'},
    url:'randomdata.php',
    root: 'Rows',
    cache: false,
    async:true,
    beforeprocessing: function(data){
    if (data) {
    /* here this function is called twice */
    virtualmode: true,
    rendergridrows: function(){
    return dataAdapter.records;
    <body>
    <input type="button" value="Load Data" id='btnLoad'/>
    <div id="jqxgrid"></div>
    <div id="eventsLog" style="margin-top: 10px;"> </div>
    here is the server side script – generates random data {randomdata.php}
    <?php
    /*simulated data as if coming from MySql*/
    /*this is just a random text data*/
    $rows=10;
    for($r=1;$r<=$rows;$r++) {
    $ln = substr(str_shuffle(str_repeat("abcdefghijklmnopqrstuvwxyz", 6)), 0, 5); /*Lastname*/
    $fn = substr(str_shuffle(str_repeat("abcdefghijklmnopqrstuvwxyz", 8)), 0, 5); /*Firstname*/
    $int= mt_rand(100000000,1262055681);
    $bdate = date("m-d-Y",$int);
    $rowdata[]=array(
    'col1'=>ucfirst($ln),
    'col2'=>ucfirst($fn),
    'col3'=>$bdate
    $data[] = array(
    'TotalRows' => $rows,
    'Rows' => $rowdata
    writetofile(json_encode($data)); /* writes data to text file -> logs.txt */
    echo json_encode($data);
    this function will write data to text file
    this will check if this script is called twice
    function writetofile($content) {
    $filename="logs.txt";
    $file = fopen($filename, 'a'); //w-> write; a->apend
    fwrite($file, $content."\n");
    fclose($file);
    am i doing it right?
    thanks,
    dan fad
    The following code should not be there:
    virtualmode: true,
    If you want to load a Grid with data, then just set its “source” property. The other 2 properties should be set during the initialization.
    Dan Fad
    Hello Peter,
    Thank you for the reply.
    I transferred these two properties in the initialization stage (virtualmode and rendergridrows) but when I clicked the Load button, the data were not shown in the grid. Only the loader image is shown.
    Am I missing some properties?
    Dan Fad
    Most probably that is due to the fact that you will try to access “return dataAdapter.records;” and dataAdapter will be undefined. I suppose that you will have to either define the dataAdapter before that or use the “rendergridrows” “data” parameter instead.
    Dan Fad
    Hi Peter
    I transferred the initialization of the source and dataAdapter on top of the grid. This solves the problem.
    Thank you very much,
    Dan Fad
    ngc2
    How can you get this to work with server-side pagination?
