jQuery UI Widgets › Forums › Plugins › AngularJS › grid does not work with ui router!
This topic contains 8 replies, has 4 voices, and was last updated by Peter Stoev 9 years, 9 months ago.
Hey There
Result of the following code is an empty page, but firebug shows that data from this url ‘/Person/GetListData’ fetched.returned data:
[{“Id”:1,”FirstName”:”a”,”LastName”:”aa”},{“Id”:2,”FirstName”:”b”,”LastName”:”bb”},{“Id”:3,”FirstName”:”c”,”LastName”:”cc”}]app.js
var app = angular .module("app", ["ui.router", "jqwidgets"]) .config(function ($stateProvider, $urlRouterProvider) { app.stateProvider = $stateProvider; }) .run(function ($http) { $http({ method: 'POST', url: '/Config/GetRoutes' }).success(function (data, status) { for (i in data.routes) { app.stateProvider.state(data.routes[i].name, { url: "/" + data.routes[i].name, templateUrl: data.routes[i].url, controller: 'sectionController' }); } }); }) ; app.controller('sectionController', function ($scope, $http) { var source = { datatype: "json", datafields: [ { name: 'Id', type: 'int' }, { name: 'FirstName', type: 'string' }, { name: 'LastName', type: 'string' } ], id: 'id', type: 'POST', url: '/Person/GetListData' }; var dataAdapter = new $.jqx.dataAdapter(source); $scope.gridSettings = { width: 850, source: dataAdapter, columnsresize: true, columns: [ { text: 'FirstName', datafield: 'FirstName', width: '10%' }, { text: 'LastName', datafield: 'LastName', width: '10%' } ] }; });
view.html
<!DOCTYPE html> <html> <head> <meta charset="utf-8" /> <link rel="stylesheet" href="/Scripts/jqwidgets/styles/jqx.base.css" type="text/css" /> <link rel="stylesheet" href="/Scripts/jqwidgets/styles/jqx.orange.css" type="text/css" /> </head> <body ng-app="app"> <script src="/Scripts/angular.min.js"></script> <script src="/Scripts/angular-ui-router.min.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxangular.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxinput.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.columnsresize.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.filter.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.sort.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.pager.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.grouping.js"></script> <script type="text/javascript" src="/Scripts/jqwidgets/jqxcheckbox.js"></script> <script src="/Scripts/app.js"></script> <div id="content"> <section ui-view></section> </div> </body> </html>
template:
<jqx-grid jqx-settings="gridSettings"></jqx-grid>
Hi n1ma,
jQWidgets requires reference to jQuery Framework. Where is this reference in your code?
http://www.jqwidgets.comhi Peter
Th original code has reference to jquery 2.1.3. We used an asp.net mvc helper for referencing javascripts but they are replaced for this post
I copied this from Firebug net tab
GET Person
200 OK
localhost:1504
1.7 KB
[::1]:1504
7ms
GET site.css200 OK
localhost:1504
237 B
[::1]:1504
1ms
GET jqx.base.css200 OK
localhost:1504
25.5 KB
[::1]:1504
12ms
GET jqx.orange.css200 OK
localhost:1504
2.0 KB
[::1]:1504
17ms
GET jquery-2.1.3.js200 OK
localhost:1504
241.6 KB
[::1]:1504
89ms
GET angular.min.js200 OK
localhost:1504
123.0 KB
[::1]:1504
50ms
GET angular-ui-router.min.js200 OK
localhost:1504
29.2 KB
[::1]:1504
86ms
GET jqxcore.js200 OK
localhost:1504
34.2 KB
[::1]:1504
95ms
GET jqxangular.js200 OK
localhost:1504
27.2 KB
[::1]:1504
116ms
GET jqxdata.js200 OK
localhost:1504
86.0 KB
[::1]:1504
147ms
GET jqxinput.js200 OK
localhost:1504
14.4 KB
[::1]:1504
154ms
GET jqxbuttons.js200 OK
localhost:1504
12.4 KB
[::1]:1504
102ms
GET jqxscrollbar.js200 OK
localhost:1504
28.8 KB
[::1]:1504
133ms
GET jqxmenu.js200 OK
localhost:1504
49.1 KB
[::1]:1504
149ms
GET jqxlistbox.js200 OK
localhost:1504
73.5 KB
[::1]:1504
224ms
GET jqxdropdownlist.js200 OK
localhost:1504
36.7 KB
[::1]:1504
224ms
GET jqxgrid.js200 OK
localhost:1504
230.4 KB
[::1]:1504
245ms
GET jqxgrid.selection.js200 OK
localhost:1504
29.9 KB
[::1]:1504
243ms
GET jqxgrid.columnsresize.js200 OK
localhost:1504
11.9 KB
[::1]:1504
149ms
GET jqxgrid.filter.js200 OK
localhost:1504
40.7 KB
[::1]:1504
150ms
GET jqxgrid.sort.js200 OK
localhost:1504
5.3 KB
[::1]:1504
220ms
GET jqxgrid.pager.js200 OK
localhost:1504
21.1 KB
[::1]:1504
219ms
GET jqxgrid.grouping.js200 OK
localhost:1504
30.8 KB
[::1]:1504
240ms
GET jqxcheckbox.js200 OK
localhost:1504
11.9 KB
[::1]:1504
253ms
GET app.js200 OK
localhost:1504
1.7 KB
[::1]:1504
252ms
POST GetRoutes200 OK
localhost:1504
98 B
[::1]:1504
2ms
GET icon-down.png200 OK
localhost:1504
142 B
[::1]:1504
2ms
27 requests
Hi n1ma,
I don’t know why you’re copying the information from the network tab. It would be better if you provide Full Example which someone from the Forum can look at or send a complete sample to support@jqwidgets.com if you’re licensed customer.
http://www.jqwidgets.comBecause I’m sure that is a bug, so I copied from net tab as a proof that no reference was missed and also that is a working example that everyone can test it. one of my friends tested it too, same behavior.
I hit the same issue. It seems like this is a change in behavior in version 3.8 where jqxGrid / jqxangular does not work as expected inside of a ui-view.
Try the previous version 3.7; that still works for me.Hi tommut,
If we reproduce the reported behavior, we will look into it in the future.
http://www.jqwidgets.comI was seeing an issue when I upgraded from jqWidgets 3.7.x to 3.8.x.
Some widgets were failing to initialize. (jqxGrid,jqxDropDownList, etc…)
The javascript console was showing the following exception:angular.min.js:102 TypeError: J.controller is not a function
at a (jqxangular.js:7)
at m (jqxangular.js:7)
at n (jqxangular.js:7)
at X (jqxangular.js:7)
at Y (jqxangular.js:7)
at jqxangular.js:7
at angular.min.js:114
at l.$eval (angular.min.js:125)
at l.$digest (angular.min.js:122)
at l.$apply (angular.min.js:126)See the following fiddle to demonstrate: https://jsfiddle.net/3xz1bjqj/8/
What I determined was that the order in which you load the javascript libraries makes a difference when using jqWidgets 3.8.x
The issue occurs when you load jquery after the angular.js libraries like this:
<script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/angularjs/1.3.13/angular.min.js"></script> <script type="text/javascript" src="https://cdnjs.cloudflare.com/ajax/libs/angular-ui-router/0.2.15/angular-ui-router.min.js"></script> <script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.3/jquery.min.js"></script> <script type="text/javascript" src="https://jqwidgets.com/public/jqwidgets/jqx-all.js"></script> <script type="text/javascript" src="https://www.jqwidgets.com/public/jqwidgets/jqxangular.js"></script>
If you load jquery FIRST like below, the exception disappears:
<script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.3/jquery.min.js"></script> <script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/angularjs/1.3.13/angular.min.js"></script> <script type="text/javascript" src="https://cdnjs.cloudflare.com/ajax/libs/angular-ui-router/0.2.15/angular-ui-router.min.js"></script> <script type="text/javascript" src="https://jqwidgets.com/public/jqwidgets/jqx-all.js"></script> <script type="text/javascript" src="https://www.jqwidgets.com/public/jqwidgets/jqxangular.js"></script>
The order does not seem to matter (ie. loading jquery after angular) when using jqWidgets 3.7.x
Hi markncs,
– jqx-all.js includes jqxangular.js so it’s not necessary to load it twice. If controller is not a function is the exception, then this means that AngularJS is not loaded.
