jQuery UI Widgets › Forums › Grid › grid does not display column names if more than 30 columns
Tagged: columns, Header, issue, jqxGrid ;, not visualizing
This topic contains 4 replies, has 4 voices, and was last updated by totomo 4 years, 5 months ago.
With V5.5.0 dynamic columns setting in grid prevent display of column names for columns after the 30th column
This worked fine with previous versions.
Here is a test case (hit the “set columns” button to see the result) :var data = generatedata(50); var source = { localdata: data, datafields: [{ name: 'firstname', type: 'string' }, { name: 'lastname', type: 'string' }, { name: 'productname', type: 'string' }, { name: 'date', type: 'date' }, { name: 'quantity', type: 'number' }, { name: 'price0', type: 'number' }, { name: 'price1', type: 'number' }, { name: 'price2', type: 'number' }, { name: 'price3', type: 'number' }, { name: 'price4', type: 'number' }, { name: 'price5', type: 'number' }, { name: 'price6', type: 'number' }, { name: 'price7', type: 'number' }, { name: 'price8', type: 'number' }, { name: 'price9', type: 'number' }, { name: 'price10', type: 'number' }, { name: 'price11', type: 'number' }, { name: 'price12', type: 'number' }, { name: 'price13', type: 'number' }, { name: 'price14', type: 'number' }, { name: 'price15', type: 'number' }, { name: 'price16', type: 'number' }, { name: 'price17', type: 'number' }, { name: 'price18', type: 'number' }, { name: 'price19', type: 'number' }, { name: 'price20', type: 'number' }, { name: 'price21', type: 'number' }, { name: 'price22', type: 'number' }, { name: 'price23', type: 'number' }, { name: 'price24', type: 'number' }, { name: 'price25', type: 'number' }, { name: 'price26', type: 'number' }, { name: 'price27', type: 'number' }, { name: 'price28', type: 'number' }, { name: 'price29', type: 'number' }, { name: 'price30', type: 'number' }, { name: 'price31', type: 'number' }, { name: 'price32', type: 'number' }, { name: 'price33', type: 'number' }, { name: 'price34', type: 'number' }, { name: 'price35', type: 'number' }, { name: 'price36', type: 'number' }, { name: 'price37', type: 'number' }, { name: 'price38', type: 'number' }, { name: 'price39', type: 'number' }], datatype: "array" }; var columns = [{ text: 'First Name', datafield: 'firstname', width: 90 }, { text: 'Last Name', datafield: 'lastname', width: 90 }, { text: 'Product', datafield: 'productname', width: 170 }, { text: 'Order Date', datafield: 'date', width: 160, cellsformat: 'dd-MMMM-yyyy' }, { text: 'Quantity', datafield: 'quantity', width: 80, cellsalign: 'right' }, { text: 'Unit Price', datafield: 'price', cellsalign: 'right', cellsformat: 'c2' }]; var columns2 = [{ text: 'Order Date', datafield: 'date', width: 160, cellsformat: 'dd-MMMM-yyyy' }, { text: 'Col2', datafield: 'price2', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col3', datafield: 'price3', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col4', datafield: 'price4', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col5', datafield: 'price5', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col6', datafield: 'price6', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col7', datafield: 'price7', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col8', datafield: 'price8', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col9', datafield: 'price9', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col10', datafield: 'price10', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col11', datafield: 'price11', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col12', datafield: 'price12', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col13', datafield: 'price13', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col14', datafield: 'price14', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col15', datafield: 'price15', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col16', datafield: 'price16', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col17', datafield: 'price17', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col18', datafield: 'price18', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col19', datafield: 'price19', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col20', datafield: 'price20', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col21', datafield: 'price21', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col22', datafield: 'price22', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col23', datafield: 'price23', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col24', datafield: 'price24', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col25', datafield: 'price25', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col26', datafield: 'price26', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col27', datafield: 'price27', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col28', datafield: 'price28', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col29', datafield: 'price29', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col30', datafield: 'price30', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col31', datafield: 'price31', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col32', datafield: 'price32', cellsalign: 'right', cellsformat: 'c2' }, { text: 'Col33', datafield: 'price33', cellsalign: 'right', cellsformat: 'c2' }]; var adapter = new $.jqx.dataAdapter(source); $("#jqxgrid").jqxGrid({ width: 500, theme: 'energyblue', source: adapter, columns: columns }); $("#columnsButton").jqxButton({ theme: 'energyblue' }); $("#columnsButton").click(function () { $("#jqxgrid").jqxGrid({ columns: columns2, width: 2000 }); });
Hello jpm78,
Thank you for reporting this issue to us!
A fix should be out in the near future.Best Regards,
StanislavjQWidgets Team
http://www.jqwidgets.com/Hi Stanislav,
I still meet this issue in jQWidgets v10.1.6 (2020-Oct)
Is this issue is fixed?Hello totomo,
Could you clarify it?
I tested this example and it seems to work fine.Best Regards,
Hristo HristovjQWidgets team
https://www.jqwidgets.comHi Hristo,
Sorry I found it’s my columns settings in wrong structure, no used array.
Thanks for your response.Otherwise, could you help solve this issue?
https://www.jqwidgets.com/community/topic/jqxpivotgrid-render-data-error/ -
