jQuery UI Widgets › Forums › Grid › Grid disapears after button click
This topic contains 1 reply, has 1 voice, and was last updated by purell007 11 years, 3 months ago.
After button click, the grid shows up for a second then disappears. When it shows up, the data is correct. The disapearing problem is my issue.
<%@ Page Language=”C#” AutoEventWireup=”true” CodeFile=”JQXgrid.aspx.cs” Inherits=”JQXgrid” %>
<!DOCTYPE html PUBLIC “-//W3C//DTD XHTML 1.0 Transitional//EN” “http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd”>
<html xmlns=”http://www.w3.org/1999/xhtml”>
<head runat=”server”>
<title></title>
<link rel=”stylesheet” href=”Scripts/jqwidgets/styles/jqx.base.css” type=”text/css” />
<script type=”text/javascript” src=”Scripts/jquery-1.10.2.min.js”></script>
<script type=”text/javascript” src=”Scripts/jquery-ui.min.js”></script>
<script type=”text/javascript” src=”Scripts/jqwidgets/jqxcore.js”></script>
<script type=”text/javascript” src=”Scripts/jqwidgets/jqxdata.js”></script>
<script type=”text/javascript” src=”Scripts/jqwidgets/jqxbuttons.js”></script>
<script type=”text/javascript” src=”Scripts/jqwidgets/jqxscrollbar.js”></script>
<script type=”text/javascript” src=”Scripts/jqwidgets/jqxmenu.js”></script>
<script type=”text/javascript” src=”Scripts/jqwidgets/jqxgrid.js”></script>
<script type=”text/javascript” src=”Scripts/jqwidgets/jqxgrid.selection.js”></script>
<script type=”text/javascript” src=”Scripts/jqwidgets/jqxgrid.filter.js”></script>
<script type=”text/javascript” src=”Scripts/jqwidgets/jqxgrid.sort.js”></script>
<script type=”text/javascript” src=”Scripts/demos.js”></script></head>
<body>
<form id=”form1″ runat=”server”>
$(‘#<%=BtnGo.ClientID %>’).click(function () {source = {
datatype: “xml”,
{ name: ‘A’ },
{ name: ‘B’ },
{ name: ‘C’ }
async: false,
record: ‘Table’,
url: ‘JQXgrid.aspx/BindDataJqxGrid’,
{ contentType: ‘application/json; charset=utf-8’}
$(“#jqxgrid”).jqxGrid({
theme: ‘classic’,
{ text: ‘A’, dataField: ‘A’, width: 250 },
{ text: ‘B’, dataField: ‘B’, width: 150 },
{ text: ‘C’, dataField: ‘C’, width: 180 }
</script><asp:Button ID=”BtnGo” runat=”server” Text=”Go” Width=”63px” />
<div id=”jqxgrid”></div>
</form>
</html>It was because of the asp button. If I make it a html input button it works then.
