jQuery UI Widgets Forums Grid Grid data not updated SecondTime
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 11 years, 11 months ago.
  • Grid data not updated SecondTime #21726
    mithun joshi
    I am fetching data for grid from java controller class.
    For the first time i call “url: ‘planningSummaryGrid.htm'” and data is fetched properly from java controller.
    For Second time when i try to reload the same grid “url: ‘planningSummaryGrid.htm'” to get updated data request is not going to java controller class. Old data fetched during first request is only shown.
    This happens mainly in IE9. for IE8 things are working fine.
    Code for reference.
    var locationSummaryGrid =
    datafields: dataFieldColumns,
    url: ‘planningSummaryGrid.htm’
    Kindly suggest.
    Grid data not updated SecondTime #21728
    To make an update of the Grid’s data, you need to either set its “source” property to point to a new jqxDataAdapter instance or to call its “updatebounddata” method. Make sure that you use jQWidgets 2.8.3, too.
    Best Wishes,
