jQuery UI Widgets Forums Grid Grid Aggregate values not Showing
This topic contains 7 replies, has 3 voices, and was last updated by  Dimitar 9 years, 2 months ago.
  • Grid Aggregate values not Showing #79988
    amitsaha
    I have a weird situation where the aggregate sum is not showing however the grid where sum should be displayed that is not coming.
    My Implementation includes Backbone with require js
    My suspect is that the require dependencies may not be right however jqxgrid.aggregates.js is loading.
    My code below
    main.js for dependencies
    shim: {
            underscore: {
                exports: '_'
            backbone: {
                deps: [
                    'underscore',
                    'jquery'
                exports: 'Backbone'
            handlebars: {
                exports: 'Handlebars'
            bootstrap: {
                deps: [
                    'jquery'
                exports: 'bootstrap',
            bootstrap_select: {
                deps: [
                    'underscore',
                    'jquery'
                exports: 'BootsrtrapSelect',
            jqxcore: {
                export: "$",
                deps: ['jquery']
            jqxwindow: {
                export: "$",
                deps: ['jquery', "jqxcore"]
            jqxdata: {
                export: "$",
            jqxbuttons: {
                export: "$",
            jqxscrollbar: {
                export: "$",
            jqxmenu: {
                export: "$",
            jqxgrid: {
                export: "$",
            jqxgrid_selection: {
                export: "$",
                deps: ['jquery', "jqxgrid"]
            jqxgrid_aggregates: {
                export: "$",
            jqxgrid_columnsresize: {
                export: "$",
                deps: ['jquery', "jqxgrid"],
            jqxgrid_columnsreorder: {
                export: "$",
            jqxgrid_sort: {
                export: "$",
            jqxexpander: {
                export: "$",
            jqxdragdrop: {
                export: "$",
            jqxsplitter: {
                export: "$",
            jqxtooltip: {
                export: "$",
    And Implementation
    initialize: function() {
    this.dailyLoacalSource =
    datafields:
    { name: ‘skill’, type: ‘string’ },
    { name: ‘cumlSl’, type: ‘number’ },
    { name: ‘ibcallOffered’, type: ‘number’ },
    { name: ‘avgAbandonTime’, type: ‘number’ },
    { name: ‘callsAbandoned’, type: ‘number’ },
    { name: ‘callAHT’, type: ‘number’ },
    { name: ‘aSA’, type: ‘number’ },
    { name: ‘cumlAbandonedRate’, type: ‘number’ },
    { name: ‘totalCallsAnswered’, type: ‘number’ }
    datatype: “array”
    renderDailyMetrics:function(){
    dailyColumns = [
    { text: ‘Skill’, dataField: ‘skill’, minwidth: 40, rendered: this.tooltiprenderer, cellsalign: ‘right’ },
    { text: ‘Cuml SL’, dataField: ‘cumlSl’, minwidth: 40, rendered: this.tooltiprenderer, cellsalign: ‘right’,aggregates: [‘sum’, ‘avg’] },
    { text: ‘I/B Calls Offered’, dataField: ‘ibcallOffered’, minwidth: 40, rendered: this.tooltiprenderer, cellsalign: ‘right’,aggregates: [‘sum’, ‘avg’] },
    { text: ‘Avg Abandoned Time’, dataField: ‘avgAbandonTime’, minwidth: 40, rendered: this.tooltiprenderer, cellsalign: ‘right’ },
    { text: ‘Calls Abandoned’, dataField: ‘callsAbandoned’, minwidth: 40, rendered: this.tooltiprenderer, cellsalign: ‘right’ },
    { text: ‘Call AHT’, dataField: ‘callAHT’, cellsalign: ‘right’, minminwidth: 40, rendered: this.tooltiprenderer, cellsalign: ‘right’},
    { text: ‘ASA’, dataField: ‘aSA’, minwidth: 40, rendered: this.tooltiprenderer, cellsalign: ‘right’ },
    { text: ‘Cuml Abandoned Rate’, dataField: ‘cumlAbandonedRate’, minwidth: 40, rendered: this.tooltiprenderer, cellsalign: ‘right’ },
    { text: ‘Total Calls Answered’, dataField: ‘totalCallsAnswered’, minwidth: 40, rendered: this.tooltiprenderer, cellsalign: ‘right’ }
    var dataAdapter = new $.jqx.dataAdapter(this.dailyLoacalSource);
    // create data grid.
    $(“#daily”).jqxGrid(
    width: ‘98%’,
    height: 200,
    columnsreorder: false,
    columns: dailyColumns,
    enabletooltips: true,
    columnsautoresize: true,
    showaggregates: true
    $(‘#queueSplitter’).jqxSplitter({orientation: ‘horizontal’, width: ‘100%’, height: 400, panels: [{ size: 200 ,collapsible: false}, { size: 200,collapsible: false}] });
    $(‘#pageSplitter’).jqxSplitter({orientation: ‘horizontal’, width: ‘100%’, height: 1000, panels: [{ size: 200 ,collapsible: false}, { size: 200,collapsible: false}] });
    this.getDailyMetrics();
    getDailyMetrics: function(){
    //var loacalSource = loacalSource;
    var prev_this = this;
    var param = “”;
    if(!!this.selectSkillInterval){
    param = this.selectSkillInterval.toString();
    } else{
    param = this.skill.toString();
    var data = {“skill”: param};
    //console.log(data);
    this.dailyMetricCollection.fetch({
    url : (isLocal) ? (‘js/jsons/daily.json’) : (prev_this.url + ‘/dailystat’),
    data: JSON.stringify(data),
    type: “POST”,
    dataType: “JSON”,
    contentType: “application/json”,
    .done(function() {
    prev_this;
    //debugger;
    prev_this.dailyLoacalSource.localdata = prev_this.dailyMetricCollection.toJSON();
    $(“#daily”).jqxGrid(‘updatebounddata’, ‘cells’);
    As you can see in the initialize I am declaring fields in the variable called dailyLoacalSource
    In renderDailyMetrics function I am defining my grid with columns and assigning fields from variable dailyLoacalSource
    and in get getDailyMetrics function I am making ajax call and assigning the response to datasource of grid
    and then updating the grid . Now the grid implementation is correct as the grid data is coming properly only the aggregate is not coming
    Screen shot below
    Please look into this
    Screen shot
    Grid Aggregate values not Showing #79990
    amitsaha
    Url of the screenshot posted by me.
    I was not able to understand how to post screenshot here
    http://postimg.org/image/7qw6jvg09/
    Grid Aggregate values not Showing #80004
    Hello amitsaha,
    You also need to set the property showstatusbar to true. Here is an example that shows how to display aggregates: http://jsfiddle.net/jqwidgets/8BE5w/.
    Grid Aggregate values not Showing #80009
    amitsaha
    Hi Dimitar I tried making show statusbar to true but no luck
                $("#daily").jqxGrid(
                  	width: '98%',
                  	height: 200,
                    showstatusbar: true,
                    columns:  columns,
    I am suspecting two things
    First may be I am missing any import
    This is the list of jqz imports that I am making
    	'jqxcore',
    	'jqxwindow',
    	'jqxdata',
    	'jqxbuttons',
    	'jqxscrollbar',
    	'jqxmenu',
    	'jqxgrid',
    	'jqxgrid_selection',
    	'jqxgrid_aggregates',
    	'jqxgrid_columnsresize',
    	'jqxgrid_columnsreorder',
    	'jqxgrid_sort',
    	'jqxexpander',
    	'jqxdragdrop',
    	'jqxsplitter',
    	'jqxtooltip',
    Second in my implementation first I am<strong> defining source </strong>
    this.dailySource =
    datafields:
    datatype: “array”
    Then Columns
                    this.dailyColumns = [
    					{ text: 'Skill', dataField: 'skill', minwidth: 40,  rendered: this.tooltiprenderer, cellsalign: 'right' },
    					{ text: 'Cuml SL', dataField: 'cumlSl', minwidth: 40,  rendered: this.tooltiprenderer, cellsalign: 'right',aggregates: ['sum', 'avg'] },
    					{ text: 'I/B Calls Offered', dataField: 'ibcallOffered', minwidth: 40,  rendered: this.tooltiprenderer, cellsalign: 'right',aggregates: ['sum', 'avg'] },
    					{ text: 'Avg Abandoned Time', dataField: 'avgAbandonTime', minwidth: 40, rendered: this.tooltiprenderer, cellsalign: 'right' },
    					{ text: 'Calls Abandoned', dataField: 'callsAbandoned', minwidth: 40, rendered: this.tooltiprenderer, cellsalign: 'right' },
    					{ text: 'Call AHT', dataField: 'callAHT', cellsalign: 'right', minminwidth: 40,  rendered: this.tooltiprenderer, cellsalign: 'right'},
    					{ text: 'ASA', dataField: 'aSA', minwidth: 40,  rendered: this.tooltiprenderer, cellsalign: 'right' },
    					{ text: 'Cuml Abandoned Rate', dataField: 'cumlAbandonedRate', minwidth: 40,  rendered: this.tooltiprenderer, cellsalign: 'right' },
    					{ text: 'Total Calls Answered', dataField: 'totalCallsAnswered', minwidth: 40,  rendered: this.tooltiprenderer, cellsalign: 'right' }
    As I want aggregate on second field Cuml Sl so I defined aggregate there
    <strong>
    Now I define my grid </strong>
    width: ‘98%’,
    height: 200,
    columns: columns,
    Then In ajax call I am assigning data to grid
    				url : (isLocal) ? ('js/jsons/daily.json') : (prev_this.url + '/dailystat'),
    				type: "POST",
    				dataType: "JSON",
    				contentType: "application/json",
    				.done(function() {
    				prev_this;
    				//debugger;
                    $("#daily").jqxGrid('updatebounddata', 'cells');
                    prev_this.setDailyThreshold();
    This my sample response JSON data
    “skill”: “CS_ASM_ENG”,
    “dbID”: “918”,
    “cumlSl”: “11”,
    “ibcallOffered”: “4”,
    “avgAbandonTime”: “4”,
    “callsAbandoned”: “4”,
    “callAHT”: “4”,
    “aSA”: “4”,
    “cumlAbandonedRate”: “4”,
    “totalCallsAnswered”: “4”,
    “cumlSlTh”: “high”,
    “ibcallOfferedTh”: “high”,
    “avgAbandonTimeTh”: “medium”,
    “callsAbandonedTh”: “high”,
    “callAHTTh”: “medium”,
    “aSATh”: “medium”,
    “cumlAbandonedRateTh”: “medium”,
    “totalCallsAnsweredTh”: “medium”
    “skill”: “CS_BSG_ENG”,
    “dbID”: “919”,
    “cumlSl”: “9”,
    “callAHT”: “4”,
    “aSA”: “4”,
    “cumlSlTh”: “medium”,
    “avgAbandonTimeTh”: “low”,
    “callAHTTh”: “low”,
    “aSATh”: “high”,
    “skill”: “CS_BSG_SPA”,
    “dbID”: “920”,
    “cumlSl”: “4”,
    “callAHT”: “4”,
    “aSA”: “4”,
    “ibcallOfferedTh”: “low”,
    “avgAbandonTimeTh”: “high”,
    “callAHTTh”: “low”,
    “aSATh”: “medium”,
    “cumlSl” the field on which I am assigning aggregate hence in source type defined as number
    Am I missing any thing
    Grid Aggregate values not Showing #80010
    amitsaha
    I got the Issue I had to set the statusbarheight: property meanwhile I have another issue now I there any way I can keep the sum as the last row as now sum is going inside the spitter I am using, can I remove all the blank cells.
    Grid Aggregate values not Showing #80071
    Hi amitsaha,
    The built-in aggregates are always displayed in the grid’s statusbar, but, if you wish, you can use cellsrenderer to show custom information in your last row.
    Grid Aggregate values not Showing #80100
    m.nour
    How about after grouping, any sample for each group aggregate?
    Please help.
    Thnx.
    Grid Aggregate values not Showing #80227
    Hi m.nour,
    You can achieve this with the groupsrenderer callback function, as shown in the demo Groups Renderer.
