jQuery UI Widgets Forums Grid Gird slowness with using cellclassname & cellsrenderer
This topic contains 5 replies, has 2 voices, and was last updated by  Peter Stoev 8 years, 2 months ago.
  • hurricane
    I am having a grid with selectionmode:’multiplecellsadvanced’. I have used grid addrow feature to add multiple rows at a time. When I tried adding 500+ rows grid having performance impact and observed slowness . When I tried adding 1000+ rows then got the browser wait/ignore prompt twice and able to render rows after 1:34 mins.
    I wanted to primarily use this grid to support more than 1000 rows addition in a single go. I am having 16+ columns to add in a row (hope this is not having any additional impact on time being taken). Event which were used :
    1. cellclassname : This is to highlight cells based on the certain dependent values. This event is applied to 2 of the columns
    2. cellsrenderer : This is applied to 3 columns in grid.
    I tried removing these event and timing reduced up to 60s and It came upto 30s. Also, I am having a tough time scrolling grid having a large number of rows.
    Please suggests if we have some attribute to set while dealing with huge data.
    Regards.
    Hi hurricane,
    Depending on your custom implementation of these functions, the performance will depend on your code, because you override a built-in logic.
    hurricane
    Thanks for the reply. I agree on your comments that custom logic might have affected the performance. But that too a one liner logic applying css to columns based on the value defined . Here is the code for cellclassname : highlightFirstName ,
    var highlightFirstName =  function (row, column, value, data) {
    	if(data[column]!=null && column == 'firstname' && data[column] == 'Peter')
                    return "highlightClass";
    cellsrenderer : checkvalidValues
    var _checkvalidValues = function (index, datafield, value, defaultvalue, column, rowdata) {
    	if(rowdata[datafield]!=null && datafield == 'zip')
    		if(jQuery.inArray(rowdata[datafield],validziplist) ==-1)
    			return "<div style='margin: 6px; color:red; font-weight: bold;'/>"+rowdata[datafield] +"</div>";
    I also would like to highlight my observation for different browser I have used to see this performance diff.
    chrome : Version 56.0.2924.87
    firefox :51.0.1 (32-bit)
    stats for row addition :
    No of rows 23 | 46 | 92 | 184 | 368 | 736 | 1472 | 2944
    chrome (ms) 191.827 | 182.914 | 211.945 | 300.316 | 629.13 | 1950.169 | 7434.451 | 25042.355
    firefox (ms) 335.13 | 338.44 | 433.95 | 952.71 | 3219.47 | 11945.91 | 46510.31 | 190485.82
    I hope this information is helpful for you to check the performance with 1000+ rows .
    Hi hurricane,
    We are happy with the Grid’s performance and do not think changes are needed there from our side. 210ms for 30 000 rows in our online demo with Chrome: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/largedataset.htm?light. I also hope that you don’t call addrow 500 times to add a row, but seeing your perf. data I guess that is the case. Well, you should have only 1 method call.
    hurricane
    I looked at the example given above. I am also having the similar implementation for the grid in addition to it I have used the 2 events as described in my previous post. Also, My data binding is of type JSON not Array (hope this is not making any diff). To confirm, yes, I have used a single call to addrow to add all of the rows in one go.
    My json object is consist of 19 properties.
    var commit = $("#jqxGrid").jqxGrid('addrow', null, datarows); //datarows - will have the list of rows to add
    By commenting out the code for 2 events ( cellclassname & cellsrenderer) , I could see some improvements in performance. But, As stated by you, It is no where coming to 210ms for 1000+ rows.
    I would like to know your thoughts on this.
    Regards.
    Hi hurricane,
    From this information i cannot tell what you’re doing wrong to get poor performance like minutes. Never seen such thing. My suggestion is to share a jsfiddle.net sample or look at our examples to see how we do the things.
