jQuery UI Widgets › Forums › Lists › DropDownList › generic php search engine
This topic contains 2 replies, has 1 voice, and was last updated by claudegel 10 years, 4 months ago.
is it possible to pass the table name and other parameter like where clause, order by close in the request to the php file that will do the data search in a myswl database
I need to create a generic php search engine file that can retreive data from any mysql table giving that I provide the needed information when I’m calling the php file
something like
cache: false,
select: true, <– allow to do a select query on the database, could be replace by a update: true so we call the same php file and it switch to the correct action
base: “client”, <– database table name
{name: ‘nocli’},
{name: ‘nom’}
nbfield: 2,
numrow: “*”, <– max number of row retreived from the table, *=all
filtre: “”, <– where clause
ordre: “”, <–order by…
url: ‘engine.php’,
$(“#dropdownlist”).jqxDropDownList(
theme: ‘classic’,
width: 200,
height: 25,
selectedIndex: 0,
displayMember: ‘nom’,
valueMember: ‘nocli’
nothing is sent to the engine.php. Should I specify the GET or POST method ??OK now it work I can send request to the engine and get data back with the possibility to filter data on demand. My problem now is the data I<m getting back from the search engine do not show up in the dropdown list. It look like the number of item in the dropdown list is correct but I only get blanck item in the list
the data I get back is in this state:
[[“nom=>Yvan Perreault et Fils qc Inc.,nocli=>227-1”],[“nom=>Yvan Perreault et Fils Inc.,nocli=>227”],[“nom=>…..
…..,[“nom=>john doe,nocli=>612”]]my code is like this in the index.php:
var url = “../engine/index.php”;
type: “POST”,
{ name: ‘nocli’ },
{ name: ‘nom’ }
url: url,
async: false,
data: {
select: true,
dbase: “client”,
nbfield: 2,
numrow: “*”,
filtre: “-“,
ordre: “nom desc”,
field: [‘nom’, ‘nocli’]
// Create a jqxDropDownList
$(“#jqxWidget”).jqxDropDownList({
selectedIndex: 0, source: dataAdapter, displayMember: “nom”, valueMember: “nocli”, width: 200, height: 25
$(“#jqxWidget”).jqxDropDownList({placeHolder: “Choisir:”});
// subscribe to the select event.
$(“#jqxWidget”).on(‘select’, function (event) {
if (event.args) {
var item = event.args.item;
if (item) {
var valueelement = $(“<div></div>”);
valueelement.text(“Value: ” + item.value);
var labelelement = $(“<div></div>”);
labelelement.text(“Label: ” + item.label);
$(“#selectionlog”).children().remove();
$(“#selectionlog”).append(labelelement);
$(“#selectionlog”).append(valueelement);
});something should be missing to have the data showing up in my dropdown list
Ok sorry but I’ve finally found that the bug was in my php script sending a bad json encoded data
but I still don’t know how to solve it. So I<ve moved my question to the dataAdapter section.
The scrip is working if I’m sending back a know number of mysql table field data. But I need to have a php script that can handle a variable number of mysql table field data to send back via json_encoded.
fixed number of data field work great but trying to handle a variable number of field data do not work and send corrupted json data.
see my post in data Adapter sectionThanks
