jQuery UI Widgets Forums Angular Form-Model is not updated
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 7 years, 1 month ago.
  • Form-Model is not updated #99055
    ng
    Dear jQWidgets Team
    We are using your components (TextInput, DateTime, Editor, Combobox) in our application by using Angular Reactive Forms. The FormGroup or FormControl is only updated after submitting the form. According to the Angular Forms API it should be updated on every keystroke (or selecting a value by keyboard, change event). Did you implement it by using updateOn submit (Angular 5 feautre)? Or how can I get the FormControl value directly after changing its value? Do I have to create a custom form control and wrap your components?
    Thank you in advanced.
    Regards
    Form-Model is not updated #99124
    Hello ng,
    I would like to suggest you look at this demo:
    https://www.jqwidgets.com/angular/angular-input/angular-input-twowaydatabinding.htm
    The value in the </fieldset> changed on each one keystroke.
