jQuery UI Widgets › Forums › Grid › foreign collection of values for a datafield in grid not work!
This topic contains 3 replies, has 2 voices, and was last updated by Martin 6 years, 5 months ago.
Hi to all,
I try to connect two grids with foreign collection of values for a datafield parameter in dataadapter. It doesn’t work.
This is the code:$(document).ready(function () { var gblMainFiles = [ {myid:1, directory:'dirA1', filename:'example-file-A1.mp3'}, {myid:2, directory:'dirA2', filename:'example-file-A2.mp3'}, {myid:3, directory:'dirA3', filename:'example-file-A3.mp3'}, {myid:4, directory:'dirA4', filename:'example-file-A4.mp3'}, {myid:5, directory:'dirA5', filename:'example-file-A5.mp3'}, {myid:6, directory:'dirA6', filename:'example-file-A6.mp3'}, {myid:7, directory:'dirA7', filename:'example-file-A7.mp3'}, {myid:8, directory:'dirA8', filename:'example-file-A8.mp3'}, ]; // ======================================================= // SOURCES // ======================================================= var souMainFiles = { datatype: "array", localdata: gblMainFiles, datafields: [ { name: 'myid'}, { name: 'directory' }, { name: 'filename'} ] }; var daaMainFiles = new $.jqx.dataAdapter(souMainFiles, {autoBind:true}); var souPlayFiles = { datatype: "array", localdata: [], datafields: [ { name: 'myid2Play'}, { name: 'directory', value: 'myid2Play', values: {source: daaMainFiles.records, value: 'myid', name: 'directory'}}, { name: 'filename', value: 'myid2Play', values: {source: daaMainFiles.records, value: 'myid', name: 'filename'}}, ] }; var daaPlayFiles = new $.jqx.dataAdapter(souPlayFiles, {autoBind:true}); // ======================================================= // GRIDS // ======================================================= $("#grd-mainfiles").jqxGrid( { source: daaMainFiles, columns: [ { text: 'id', datafield: 'myid'}, { text: 'dir', datafield: 'directory'}, { text: 'file', datafield: 'filename'} ], }); $("#grd-playfiles").jqxGrid( { source: daaPlayFiles, columns: [ { text: 'id', datafield: 'myid2Play'}, { text: 'dir', datafield: 'directory'}, { text: 'file', datafield: 'filename'} ], }); // ======================================================= // BUTTON // ======================================================= $("#btn1").jqxButton(); $("#btn2").jqxButton(); $("#btn1").on('click', function () { var playlist = new Array(); playlist.push({'myid2Play': 2}); playlist.push({'myid2Play': 1}); playlist.push({'myid2Play': 4}); souPlayFiles.localdata = playlist; $("#grd-playfiles").jqxGrid('updatebounddata'); }); $("#btn2").on('click', function () { var mf = new Array(); var mf = [ {myid:1, directory:'dirB1', filename:'example-file-B1.mp3'}, {myid:2, directory:'dirB2', filename:'example-file-B2.mp3'}, {myid:3, directory:'dirB3', filename:'example-file-B3.mp3'}, {myid:4, directory:'dirB4', filename:'example-file-B4.mp3'}, {myid:6, directory:'dirB6', filename:'example-file-B6.mp3'}, {myid:7, directory:'dirB7', filename:'example-file-B7.mp3'}, ]; souMainFiles.localdata = mf; $("#grd-mainfiles").jqxGrid('updatebounddata'); }); });
if I click btn1, grd-playfiles get right data from grd-mainfiles.
But if I repeat click btn1 after click btn2 (that change grd-mainfiles data), nothing happens. A possible solution?
Thanks, FabioHello Fabio,
When you are updating the “playfiles” grid by clicking btn2,
you also need to updatesouPlayFiles
datafields’ values’ sources, asdaaMainFiles.records
might have changed.I have created an Example, using your code.
MartinjQWidgets Team
http://www.jqwidgets.com/Thanks Martin, now I understand, I will use your suggestion!
I thought the datafields were updated automatically. Is there an automatic way without rewriting the datafields source each time?
FabioHello Fabio,
I am glad I was able to help you!
They are not updated automatically. You should do it, as shown in the example above.Best Regards,
