jQuery UI Widgets Forums React Filteritem is not refreshed for coloumn in react
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 7 years ago.
  • sonu
    I have a dropdown box based on this i have to refresh jqxgrid and add filteritems in coloumns. But for first time when i choose the dropdown filteritems are rendered perfectly but when i change dropdown value then data is not change. It show the old data but it should be the new data. and when i apply shorting the grid header will hide the filter row jqxgrid header issue jqxgrid header issue. please help i tried with both thing updatedatabound with data and cells but won’t me. please help me on this.
    export class Jqgrid extends Component {
        constructor(props) {
            super(props);
            let letcheck = this;
            let stringified = queryString.stringify(this.props.params, { arrayFormat: 'bracket' });
            let source =
                datafields:
                    { name: 'id', type: 'number' },
                    { name: 'last_name', type: 'string' },
                    { name: 'item_descriptor', type: 'string' },
                    { name: 'product_brand', type: 'html' },
                    { name: 'is_floor_stock', type: 'bool' },
                    { name: 'created', type: 'number' },
                    { name: 'repairer_status', type: 'string' }
                datatype: 'json',
                root: 'Rows',
                cache: false,
                url:'http://eucalyptus-api.localhost.com/v1/requests/records?'+stringified,
                sort: function () {
                    letcheck.refs.myGrid.updatebounddata('sort');
                filter: function () {
                    letcheck.refs.myGrid.updatebounddata('filter');
                    //console.log(data[0].TotalRows);
                    if (data != null)
                    letcheck.refs.myGrid.updatebounddata('data');
            //console.log("props :"+JSON.stringify(source));
            this.state = {
                dataDetails: [],
                editrow: -1,
                totalNoRecord: 0,
                params: props.params,
                source:source,
                repairerStatus:statusDoc[this.props.params.selectFilter]['status_name']
        componentDidMount(){
            this.refs.myGrid.on('bindingcomplete', (event) => {
         componentWillReceiveProps(nextProps) {
            this.setState({ repairerStatus: statusDoc[nextProps.params.selectFilter]['status_name'] });
            let stringified = queryString.stringify(nextProps.params, { arrayFormat: 'bracket' });
            let temp = this.state.source;
                temp.url = 'http://myapi-url.localhost.com/v1/requests/records?'+stringified;
                //console.log("componentWillReceiveProps "+JSON.stringify(temp));
                this.setState({
                    source: temp
                this.refs.myGrid.updatebounddata('data');
                this.refs.myGrid.gotopage(0);
             //this.setState({ params: nextProps.params });
        render() {
            //let letcheck = this;
            let currentComponent = this;
            let dataAdapter = new jqx.dataAdapter(currentComponent.state.source);
            var rendergridrows = function () {
                //console.log(dataAdapter.records);
                return dataAdapter.records;
            let columns =
                    { text: 'Id', columntype: 'textbox', cellsalign: 'center', align: 'center', datafield: 'id', filterable: false },
                    { text: 'Customer', columntype: 'textbox', datafield: 'last_name', cellsalign: 'center', align: 'center' },
                    { text: 'Product', datafield: 'item_descriptor', height: '45', cellsformat: 'F2', cellsalign: 'center', align: 'center' },
                        text: 'Brand', datafield: 'product_brand', filtertype: 'checkedlist', cellsalign: 'center', align: 'center', height: '100'
                        text: 'Age', datafield: 'created', filtertype: 'number', cellsalign: 'center', align: 'center', cellsrenderer: function (row, column, value) {
                            return '<div class="jqx-grid-cell-middle-align">' + value + ' days</div>';
                    { text: 'Status', datafield: 'repairer_status', filtertype: 'checkedlist',filteritems:currentComponent.state.repairerStatus, cellsalign: 'center', align: 'center' },
                        text: 'Action', datafield: 'Edit', filterable: false, showfilterrow: false, cellsalign: 'center', align: 'center', columntype: 'button', width: 75, cellsrenderer: function () {
                            return "View";
                            currentComponent.setState({
                                editrow: row
                            let dataRecord = currentComponent.refs.myGrid.getrowdata(currentComponent.state.editrow);
                            alert(dataRecord.id);
            var theme = 'light';
            let getLocalization = () => {
                let localizationobj = {};
                localizationobj.filterselectstring = "Please Choose:";
                return localizationobj;
            return (
                <div>
                    <JqxGrid
                        ref='myGrid'
                        altrows={true}
                        className='myGrid'
                        width='100%'
                        autoheight={true}
                        sortable={true}
                        source={dataAdapter}
                        filterable={true}
                        columns={columns}
                        showfilterrow={true}
                        selectionmode={'multiplecellsextended'}
                        showsortmenuitems={false}
                        localization={getLocalization()}
                        theme={theme}
                        pageable={true}
                        virtualmode={true}
                        rendergridrows={rendergridrows}
                        autoloadstate={true}
                        autosavestate={true}
                    {/* <JqxButton ref='Button' width={125} height={25} value='Remove Filter' style={{ marginTop: 10 }} /> */}
    Hello imsonujangra,
    I saw in your code something that you try to add extra variables to the URL.
    I would like to suggest you look at this tutorial, it could be helpful:
    https://www.jqwidgets.com/jquery-widgets-documentation/documentation/jqxgrid/jquery-grid-extra-http-variables.htm?search=grid
    The data property of the source and the formatData callback of the DataAdapter are more important for this case.
