jQuery UI Widgets Forums Grid Filtering Events for localdata
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 8 years, 2 months ago.
  • Filtering Events for localdata #91785
    Gaetek
    I’d like to know the best practice to determine when the grid as completed filtering in the case of local data (no server side filtering).
    I can’t find a way to determine when the complete rendering is done and so I can count the number of filtered rows.
    I tried: ready, rendered, filtered and none worked (filtered fires too many time, it fires at every row creation).
    Any help?
    Gaetano
    Filtering Events for localdata #91814
    Hello Gaetano,
    The filter event is the right place. This event is triggered when the Grid is filtered.
    I would suggest you ready callback. This function is called when the grid is initialized and the binding is complete. There you could set filter by default.
    Also, I would like to suggest you bind to filter event before to create the Grid (on that way you will catch some filtering in ready callback).
