jQuery UI Widgets Forums Lists ListBox Filterable: true when using JSON?
This topic contains 3 replies, has 2 voices, and was last updated by  realtek 9 years, 4 months ago.
  • Filterable: true when using JSON? #78125
    realtek
    Does filtering work for list boxes when using a JSON source?
    I set filterable: true but it is not even displaying the input field?
    Filterable: true when using JSON? #78172
    ivailo
    Hi realtek,
    It works works well as expected.
    Here is a demo.
    Ivailo Ivanov
    Filterable: true when using JSON? #78253
    realtek
    Hi Ivailo,
    I must be going mad, here is my code but the filter box is not showing still?
       var url = "/api/List";
                        data: {
                            SEQ: editSeq
                            { name: 'DisplayName' },
                            { name: 'Sequence' },
                            { name: 'Type' },
                            { name: 'SeqParent' }
                        url: url,
                        type: "POST",
                        async: true
            // Create a jqxListBox
            $("#ListBox").jqxListBox({ source: dataAdapter, filterable: true, checkboxes: true, allowDrag: false, enableSelection: true, equalItemsWidth: true, displayMember: "DisplayName", valueMember: "Sequence", width: '220px', height: '250px', theme: theme });
    Filterable: true when using JSON? #78260
    realtek
    ok, i’m not going mad 🙂
    I was testing this by publishing in Visual Studio and forgot to enable the option to delete all the existing files first.
    What was happening was because I had changed some file names, none of my changes were being referenced because the old files still existed.
    I could see in a web debugger that the old files were still being used!
    Sorry about this and thanks ivailo!
