jQuery UI Widgets Forums Grid Filter on string starting with "0"
This topic contains 11 replies, has 2 voices, and was last updated by  Naroth 9 years, 10 months ago.
Viewing 12 posts - 1 through 12 (of 12 total)
  • Filter on string starting with "0" #72885
    Naroth
    I’m trying to filter a grid by certain values, but on two columns I got some issues.
    var source=
    datatype : 'json',
    datafiels : [
    		{name : 'cLoginName', type:'string'},
    		{name : 'compteCodePostal', type:'string'},
    url: url,
    type : "POST"
    autowidth:true,
    autoHeight:true,
    filterable:true,
    showfilterrow : true,
    editable:true,
    // sortable:true,
    rowsHeight:40,
    { text: 'cLoginName', datafield: 'cLoginName', columntype: 'textbox', align: 'center', width: 80, editable:false, hidden:false, filtercondition: 'contains'},
    { text: 'compteCodePostal', datafield: 'compteCodePostal', columntype: 'textbox', align: 'center', cellsalign:"center", width: 150, editable:true, filtercondition : 'contains' },
    “compteCodePostal” columns contains digital strings (“42190” for example)
    “cLoginName” contains digital strings, normal strings, and alphanumeric strings
    Problems are :
    – “compteCodePostal” : using Chrome i can’t apply any digital filter or character filter (error : Uncaught TypeError: Cannot read property ‘toString’ of null). It’s work with Firefox
    – “cLoginName” : can apply digital or characters filter, but I found no line (it is supposed to find some lines) (Chrome & Firefox)
    – both : if cells value start with “0”, this “0” is not include in filters (Chrome & Firefox)
    How can I fixe theses issues ?
    I’m using jqWidgets 3.8.0.
    Thanks & Regards
    Filter on string starting with "0" #72943
    Hi Naroth,
    Please provide us with a complete example (JSFiddle/JS Editor), including some data, so that we can test your case. Share how to reproduce the issues step-by-step.
    Filter on string starting with "0" #73020
    Naroth
    Hello Dimitar,
    Sorry for delay
    I can’t replicate the issue, but I have new information.
    var source=
    datatype : 'json',
    datafiels : [
    url: url,
    type : "POST"
    When I apply a filter (using showfilterrow input),
    it apply “numericfilter” on “cLoginName” column, “compteCodePostal” column (Firefox)
    and apply “numericfilter” on “cLoginName” column, “datefilter” on “compteCodePostal” column (chrome).
    I build another grid with same data (from Json string)
    Chrome & Firfox apply “stringfilter” on both columns and obviously works well
    Got it with getfilterinformation method
    Filter on string starting with "0" #73065
    Hi Naroth,
    Please try applying a particular filtertype to each of your columns. Here is more about this property:
    filtertype – sets the filter’s type.
    ‘textbox’ – basic text field.
    ‘input’ – input field with dropdownlist for choosing the filter condition. *Only when “showfilterrow” is true.
    ‘checkedlist’ – dropdownlist with checkboxes that specify which records should be visible and hidden.
    ‘list’ – dropdownlist which specifies the visible records depending on the selection.
    ‘number’ – numeric input field. *Only when “showfilterrow” is true.
    ‘checkbox’ – filter for boolean data. *Only when “showfilterrow” is true.
    ‘date’ – filter for dates.
    ‘range’ – filter for date ranges. *Only when “showfilterrow” is true.
    ‘custom’ – allows you to create custom filter menu widgets. *Only when “showfilterrow” is false.
    $(“#jqxgrid”).jqxGrid(
    width: 670,
    showfilterrow: true,
    selectionmode: ‘singlecell’,
    { text: ‘Name’, columntype: ‘textbox’, datafield: ‘name’, width: 120 },
    { text: ‘Product’, filtertype: ‘checkedlist’, datafield: ‘productname’, width: 160 },
    { text: ‘Available’, datafield: ‘available’, columntype: ‘checkbox’, filtertype: ‘bool’, width: 67 },
    { text: ‘Ship Date’, datafield: ‘date’, filtertype: ‘date’, width: 180, cellsalign: ‘right’, cellsformat: ‘d’ },
    { text: ‘Qty.’, datafield: ‘quantity’, filtertype: ‘number’, width: 50, cellsalign: ‘right’ },
    { text: ‘Price’, datafield: ‘price’, filtertype: ‘number’, cellsalign: ‘right’, cellsformat: ‘c2’ }
    Filter on string starting with "0" #73070
    Naroth
    Hi Dimitar,
    Thanks for reply,
    I tried each filtertype property, but getfilterinformation always return “numericfilter” as filtertype. (Chrome apply “datefilter” on “compteCodePostal”).
    Filter Column: cLoginName
    Filter:
    Value: c
    Condition: LESS_THAN
    Operator: 0
    Type: numericfilter
    I got more than two columns in my grid, on others columns “stringfilter” are apply.
    function jqx_grid_bo_accounts_list_init()
    		var source=
    				datatype : 'json',
    				datafiels : [
    				             {name : 'cLoginName', type:'String'},
    				             {name : 'cbackupServerName', type:'String'},
    				             {name : 'cAlias', type:'String'},
    				             {name : 'cTypeCompte', type:'String'},
    				             {name : 'compteNom', type:'String'},
    				             {name : 'comptePrenom', type:'String'},
    				             {name : 'compteNomPharmacie', type:'String'},
    				             {name : 'compteRue', type:'String'},
    				             {name : 'compteCodePostal', type:'String'},
    				             {name : 'compteVille', type:'String'},
    				             {name : 'compteNumTel', type:'String'},
    				             {name : 'compteMail', type:'String'},
    				             {name : 'compteMailPartenaire', type:'String'},
    							 {name : 'sendMailAuto', type:'String'},
    				             {name : 'periodReport', type:'String'},
    							 {name : 'accountStatus', type:'String'},
    //				             {name : 'weeklyReport', type:'String'},
    				url: url,
    				type:'POST',
    				async: false,
    					var data = "update=true&" + $.param(rowdata);
    					console.log(data);
    	            		 dataType: 'json',
    	            		 type:'POST',
    	            		 url: url,
    	            		 cache: false,
    	            		 data: data,
    	            			 commit(true);
    	            		 error: function(jqXHR, textStatus, errorThrown)
    	            			 commit(false);
    		var initeditorPeriodReport = function(row, cellvalue, editor){
    			editor.jqxDropDownList({ source: ["Quotidien","Hebdomadaire","Aucun"], placeHolder:"Selectionnez la periodicité du rapport",displayMember: "Description", valueMember: "Title"});
    			if(cellvalue == 'Quotidien'){
    				editor.jqxDropDownList('selectIndex', 0 );
    			else if(cellvalue == 'Hebdomadaire'){
    				editor.jqxDropDownList('selectIndex', 1 );
    			else{
    				// Si il n'est ni Quotidien, ni Hebdomadaire laisser le place holder
    			editor.on('change', function (event){
    				var rowIDs = $('#jqx_grid_bo_accounts_list').jqxGrid('getselectedrowindex');
    				// console.log("rowIDs");
    				// console.log(rowIDs);
    				// $('#jqx_grid_bo_accounts_list').jqxGrid('updaterow', rowIDs, newRows);
    		var initeditorSendMailAutoReport = function(row, cellvalue, editor){
    			editor.jqxDropDownList({ source: ["Non","Oui"], placeHolder:"Envoyer les rapports automatiquement",displayMember: "Description", valueMember: "Title"});
    			if(cellvalue == 'Non'){
    			else if(cellvalue == 'Oui'){
    			else{
    		var cellsrendererPeriodReport = function (row, column, value) {
    			var PeriodReport = $('#jqx_grid_bo_accounts_list').jqxGrid('getrowdata', row).periodReport;
    			if(PeriodReport == 'Quotidien'){
    				var etat = "<div style='line-height:40px; text-align:center;'>Quotidien</div>";
    			else if(PeriodReport == 'Hebdomadaire'){
    				var etat = "<div style='line-height:40px; text-align:center;'>Hebdomadaire</div>";
    			}else{
    				// Si il n'est ni Quotidien, ni Hebdomadaire on laisse le champ vide
    				var etat = "";
    			return etat;
    		var cellsrendererSendMailAutoReport = function (row, column, value) {
    			var sendMailAuto = $('#jqx_grid_bo_accounts_list').jqxGrid('getrowdata', row).sendMailAuto;
    			if(sendMailAuto == 'Non'){
    				var etat = "<div style='line-height:40px; text-align:center;'>Non</div>";
    			else if(sendMailAuto == 'Oui'){
    				var etat = "<div style='line-height:40px; text-align:center;'>Oui</div>";
    			}else{
    				var etat = "";
    			return etat;
    		var initEditorStatus = function(row, cellvalue, editor){
    			editor.jqxDropDownList({ source: ["ACTIVE","HIDDEN","SUSPENDED","CLOSED"], placeHolder:"Statut du compte",displayMember: "Description", valueMember: "ACTIVE"});
    			if(cellvalue == 'ACTIVE'){
    			else if(cellvalue == 'HIDDEN'){
    			else if(cellvalue == 'SUSPENDED'){
    				editor.jqxDropDownList('selectIndex', 2 );
    			}else if(cellvalue == 'CLOSED'){
    				editor.jqxDropDownList('selectIndex', 3 );
    			}else{
    				// var rowIDs = $('#jqx_grid_bo_accounts_list').jqxGrid('getselectedrowindex');
    		$("#jqx_grid_bo_accounts_list").jqxGrid(
    			// width : 1520,
    			autowidth:true,
    			autoHeight:true,
    			filterable:true,
    			editable:true,
    			// sortable:true,
    			selectionmode: 'singlecell',
    			rowsHeight:40,
    			          { text: 'cLoginName', datafield: 'cLoginName', columntype: 'textbox', align: 'center', width: 80, editable:false, filtertype: 'input', hidden:false},
    			          // { text: 'cbackupServerName', datafield: 'cbackupServerName', columntype: 'textbox', align: 'center', width: 0, editable:false, hidden:true, filtercondition: 'contains' },
    			          { text: 'cAlias', datafield: 'cAlias', columntype: 'textbox', align: 'center', cellsalign:"center", width: 180, editable:true, filtertype: 'input', filtercondition: 'contains' },
    			          { text: 'cTypeCompte', datafield: 'cTypeCompte', columntype: 'textbox', align: 'center', cellsalign:"center", width: 100, editable:true, filtertype: 'input', filtercondition: 'contains' },
    			          { text: 'compteNom', datafield: 'compteNom', columntype: 'textbox', align: 'center', cellsalign:"center", width: 120, editable:true, filtertype: 'input', filtercondition: 'contains' },
    			          { text: 'comptePrenom', datafield: 'comptePrenom', columntype: 'textbox', align: 'center', cellsalign:"center", width: 110, editable:true, filtertype: 'input', filtercondition: 'contains' },
    			          { text: 'compteNomPharmacie', datafield: 'compteNomPharmacie', columntype: 'textbox', align: 'center', cellsalign:"center", width: 180, filtertype: 'input', editable:true, filtercondition: 'contains' },
    			          { text: 'compteRue', datafield: 'compteRue', columntype: 'textbox', align: 'center', cellsalign:"center", width: 180, editable:true, filtertype: 'input', filtercondition: 'contains' },
    			          { text: 'compteCodePostal', datafield: 'compteCodePostal', columntype: 'textbox', align: 'center', cellsalign:"center", width: 50, editable:true, filtertype: 'input', filtercondition: 'contains' },
    			          { text: 'compteVille', datafield: 'compteVille', columntype: 'textbox', align: 'center', cellsalign:"center", width: 150, editable:true, filtertype: 'input', filtercondition: 'contains' },
    			          { text: 'compteNumTel', datafield: 'compteNumTel', columntype: 'textbox', align: 'center',cellsalign:"center", width: 120, editable:true, filtertype: 'input', filtercondition: 'contains' },
    			          { text: 'compteMail', datafield: 'compteMail', columntype: 'textbox', align: 'center',cellsalign:"center", width: 180, editable:true, filtertype: 'input', filtercondition: 'contains' },
    			          // { text: 'compteMailPartenaire', datafield: 'compteMailPartenaire', columntype: 'textbox', align: 'center', width: 70, hidden:true, editable:true, filtercondition: 'contains' },
    					  { text: 'sendMailAuto', datafield: 'sendMailAuto', columntype: 'dropdownlist', align: 'center', cellsalign:"center", width: 40, cellsrenderer : cellsrendererSendMailAutoReport , filtertype: 'input', filtercondition: 'contains', initeditor: initeditorSendMailAutoReport},
    			          { text: 'periodReport', datafield: 'periodReport', columntype: 'dropdownlist', align: 'center', cellsalign:"center", width: 110, cellsrenderer: cellsrendererPeriodReport, initeditor : initeditorPeriodReport, filtertype: 'input', filtercondition: 'contains' },
    			          { text: 'accountStatus', datafield: 'accountStatus', columntype: 'dropdownlist', align: 'center', cellsalign:"center", width: 110, initeditor : initEditorStatus, filtertype: 'input', filtercondition: 'contains' },
    //			          { text: 'weeklyReport', datafield: 'weeklyReport', columntype: 'textbox', align: 'center', cellsalign:"center", width: 180 },
    Thanks & Regards
    Naroth
    Filter on string starting with "0" #73124
    Hi Naroth,
    Please share some of your JSON data so that we may test your code locally.
    Filter on string starting with "0" #73148
    Naroth
    Hi Dimitar,
    data : (from db return by php script)
    [{“cLoginName”:”58469″,”compteCodePostal”:”42400″}, {“cLoginName”:”45494t”,”compteCodePostal”:”42120″}];
    code :
     var sourceDeux=
    				datatype : 'json',
    				datafiels : [
    				url: url,
    				type:'POST',
    				async: false,
    					console.log(data);
    	            		 dataType: 'json',
    	            		 type:'POST',
    	            		 url: 'bo-getaccountslist.php',
    	            		 cache: false,
    	            		 data: data,
    	            			 commit(true);
    	            			 commit(false);
    			var dataAdapterDeux = new $.jqx.dataAdapter(sourceDeux);
                $("#jqxgridDEux").jqxGrid(
                    autowidth:true,
    				autoHeight:true,
    				filterable:true,
    				editable:true,
    				// sortable:true,
    				rowsHeight:40,
                    source: dataAdapterDeux,
                      { text: 'NOKcLoginName', datafield: 'cLoginName', columntype: 'textbox', align: 'center', width: 120, editable:false, hidden:false, filtercondition: 'CONTAINS'},
                      { text: 'NOKcompteCodePostal', datafield: 'compteCodePostal', columntype: 'textbox', align: 'center', cellsalign:"center", width: 120, editable:true, filtercondition: 'contains' },
        <link rel="stylesheet" href="../js/jqwidgets/styles/jqx.base.css" type="text/css" />
        <script type="text/javascript" src="jquery-1.11.1.min.js"></script>
        <script type="text/javascript" src="../js/jqwidgets/jqxcore.js"></script>
        <script type="text/javascript" src="../js/jqwidgets/jqxdata.js"></script>
        <script type="text/javascript" src="../js/jqwidgets/jqxbuttons.js"></script>
        <script type="text/javascript" src="../js/jqwidgets/jqxscrollbar.js"></script>
        <script type="text/javascript" src="../js/jqwidgets/jqxmenu.js"></script>
        <script type="text/javascript" src="../js/jqwidgets/jqxgrid.js"></script>
        <script type="text/javascript" src="../js/jqwidgets/jqxgrid.selection.js"></script>
        <script type="text/javascript" src="../js/jqwidgets/jqxgrid.filter.js"></script>
        <script type="text/javascript" src="../js/jqwidgets/jqxdropdownlist.js"></script>
        <script type="text/javascript" src="../js/jqwidgets/jqxgrid.edit.js"></script>
        <script type="text/javascript" src="../js/jqwidgets/jqxlistbox.js"></script>
        <script type="text/javascript" src="../js/jqwidgets/jqxgrid.columnsresize.js"></script>
                function getFilterjqxgriddeux(){
    			var filterGroups = $('#jqxgridDEux').jqxGrid('getfilterinformation');
    			 var info = "";
    			 for (var i = 0; i < filterGroups.length; i++) {
    				 var filterGroup = filterGroups[i];
    				 info += "Filter Column: " + filterGroup.filtercolumn;
    				 var filters = filterGroup.filter.getfilters();
    				 for (var j = 0; j < filters.length; j++) {
    					 info += "\nFilter: ";
    					 info += "\nValue: " + filters[j].value;
    					 info += "\nCondition: " + filters[j].condition;
    					 info += "\nOperator: " + filters[j].operator;
    					 info += "\nType: " + filters[j].type;
    					 info += "\n";
    					 // console.log(filters[j]);
    			 console.log(info);
        <div id='jqxWidget'>
    		<input type="button" onClick="getFilterjqxgriddeux()" value="filter info jqxgriddeux"/>
    		<div id="jqxgridDEux"></div>
    With a Json array “var data = ‘[{“cLoginName”:”58469″,”compteCodePostal”:”42400″}, {“cLoginName”:”45494″,”compteCodePostal”:”42120″}]’;” it works well.
    Thanks & Regards
    Naroth
    Filter on string starting with "0" #73152
    Naroth
    In my db “cLoginName” is a varchar(60) and “compteCodePostal” is a varchar(7)
    Filter on string starting with "0" #73187
    Hi Naroth,
    We tested the following version of your code:
                var localData = [{ "cLoginName": "58469", "compteCodePostal": "42400" }, { "cLoginName": "45494t", "compteCodePostal": "42120"}];
                var sourceDeux =
    			    datatype: 'json',
    			    datafiels: [
    				    { name: 'cLoginName', type: 'String' },
    				    { name: 'compteCodePostal', type: 'String' }
    			    localdata: localData,
    			    type: 'POST',
    			    async: false
                    autowidth: true,
                    autoHeight: true,
                    // sortable:true,
                    rowsHeight: 40,
                      { text: 'NOKcLoginName', datafield: 'cLoginName', columntype: 'textbox', align: 'center', width: 120, editable: false, hidden: false, filtercondition: 'CONTAINS' },
                      { text: 'NOKcompteCodePostal', datafield: 'compteCodePostal', columntype: 'textbox', align: 'center', cellsalign: "center", width: 120, editable: true, filtercondition: 'contains' }
    and the filtering works fine. Please share in what scenario/with what data does the example not work as expected?
    Filter on string starting with "0" #73203
    Naroth
    Hi Dimitar,
    In this case it works well.
    Try to get the data from a php script.
    Php script is the only difference between your code and mine.
    Regards
    Naroth
    Filter on string starting with "0" #73222
    Hi Naroth,
    As far as the grid is “concerned”, there is no difference between loading from local data and PHP, because the loading is handled by the data adapter. Something I notice now is that the sourceDeux property datafields is misspelled as “datafiels” and this is what may cause the issue.
    Filter on string starting with "0" #73249
    Naroth
    Hi Dimitar,
    Many thanks,
    The issue came from there.
    Maybe it should be very usefull, to make something that can alert us when we got this kind of issue.
    Thanks & Regards
    Naroth
