jQuery UI Widgets Forums Grid filter issue
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 9 years, 3 months ago.
    filter issue Posts
  • filter issue #80521
    Rajesh
    Hi All,
    I have implemented grid its working fine for all filter but not working when i apply * filter
    we have requirement like user can apply * filter for ex.– have Name field and having value Rajesh so then user can filter Raj* then get data which record having Name start from Raj..
    filter issue #80523
    Hi Rajesh,
    Please, look at our Grid’s demos about Filtering and look at what is the difference with your code. I suppose you missed some parts, because such issue does not exist in any of our demos.
    filter issue #80575
    Rajesh
    Thanks For reply
    I think you didn’t get my question let me explain better way
    suppose
    Name
    Rajesh
    Madhav
    Marry
    Ram
    Vilas
    ok then i want apply filter on name column
    with Ma* in filter textbox
    so result should be
    Name
    Madhav
    Marry
    because those two records start with Ma
    simply same like database SQl Query if you know about Database
    select * from customers where name like ‘Ma%’
    getting records
    Madhav
    Marry
    I try our all demo there also filter with * not working
    Rajesh
    filter issue #80576
    Hi Rajesh,
    You have to type “Ma” and the filter will display all records that contain “Ma” or start with “Ma” depending on the column’s filtercondition. The string “*” is Invalid i.e if you do not have a word that contain “*”, the Grid will display nothing. Again, you can try our demos in order to learn how to use the Grid’s filtering. It works in the same way as any online Grid widget.
