jQuery UI Widgets › Forums › Grid › Fail to edit 'detail' grid in master-detail grid
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 11 years, 12 months ago.
I have master-detail grid taken from your website, I am able to edit the master grid but fail to do it with the detail grid, here is the code:
<!DOCTYPE html><html lang=\"en\"><head><base href=\"<?php echo base_url();?>\"> <title id=\'Description\'>This example shows how to implement Master-Details binding scenario with two Grids.</title> <link rel=\"stylesheet\" href=\"media/js/jqwidgets/styles/jqx.base.css\" type=\"text/css\" /> <script type=\"text/javascript\" src=\"media/js/scripts/jquery-1.8.3.min.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxcore.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxbuttons.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxscrollbar.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxmenu.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxgrid.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxgrid.selection.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxgrid.columnsresize.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxgrid.pager.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxlistbox.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxdropdownlist.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxdata.js\"></script> <script type=\"text/javascript\" src=\"media/js/scripts/gettheme.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxcalendar.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxdatetimeinput.js\"></script> <script type=\"text/javascript\" src=\"media/js/jqwidgets/jqxgrid.edit.js\"></script> <script type=\"text/javascript\"> $(document).ready(function () { var theme = getTheme(); // prepare the data var countries = <?php include \"json.php\"; ?>; var countriesSource = { datatype: \"array\", datafields: [ { name: \'label\', type: \'string\' }, { name: \'value\', type: \'string\' } ], localdata: countries }; var countriesAdapter = new $.jqx.dataAdapter(countriesSource, { autoBind: true }); var source = { datatype: \"json\", datafields: [ { name: \'invoice_id\' }, { name: \'invoice_amount\' }, { name: \'due_amount\' }, { name: \'due_date\' }, { name: \'unit_no\' }, { name: \'Status\', value: \'status\', values: { source: countriesAdapter.records, value: \'value\', name: \'label\' } }, { name: \'status\', type: \'string\'} ], localdata:\'<?php include \'grid_datasource.php\'; ?>\', updaterow: function (rowid, rowdata, commit) { // synchronize with the server - send update command var data = \"update=true&due_amount=\" + rowdata.due_amount + \"&status=\" + rowdata.status + \"&invoice_id=\" +rowdata.invoice_id; $.ajax({ // dataType: \'json\', type: \"POST\", url: \'<?php echo site_url(\"invoice/updateInvoice\");?>\', data: data, success: function (data, status, xhr) { // update command is executed. commit(true); }, error: function () { // cancel changes. commit(false); } }); } }; var dataAdapter = new $.jqx.dataAdapter(source); $(\"#customersGrid\").jqxGrid( { width: 670, height: 250, source: dataAdapter, theme: theme, editable: true, keyboardnavigation: false, columns: [ { text: \'Invoice ID\', datafield: \'invoice_id\', width: 70 }, { text: \'Amount\', datafield: \'invoice_amount\', width: 70 }, { text: \'Due Amount\', datafield: \'due_amount\', width: 70 }, { text: \'Due Date\', datafield: \'due_date\', width: 100 }, { text: \'Unit No\', datafield: \'unit_no\', width: 120 }, { text: \'Status\', datafield: \'status\', displayfield: \'Status\', columntype: \'dropdownlist\', createeditor: function (row, value, editor) { editor.jqxDropDownList({ source: countriesAdapter, displayMember: \'label\', valueMember: \'value\' }); } } ] }); // Orders Grid // prepare the data var dataFields = [ { name: \'invoice_item_id\' }, { name: \'invoice_id\' }, { name: \'amount\' }, { name: \'description\' }, { name: \'from_date\' }, { name: \'to_date\' } ]; var data=\'<?php include \'detail_grid_datasource.php\'; ?>\'; var source = { datatype: \"json\", datafields: dataFields, localdata:data, updaterow: function (rowid, rowdata, commit) { alert(\"Going to update\"); // synchronize with the server - send update command var data = \"update=true&amount=\" + rowdata.amount + \"&status=\" + rowdata.status + \"&invoice_item_id=\" +rowdata.invoice_item_id; alert(data); $.ajax({ // dataType: \'json\', type: \"POST\", url: \'<?php echo site_url(\"invoice/updateInvoiceItem\");?>\', data: data, success: function (data, status, xhr) { // update command is executed. commit(true); alert(data); }, error: function () { // cancel changes. commit(false); alert(\"No\"); } }); } }; var dataAdapter = new $.jqx.dataAdapter(source); dataAdapter.dataBind(); $(\"#customersGrid\").on(\'rowselect\', function (event) { var invoice_id=event.args.row.invoice_id; var records = new Array(); var length = dataAdapter.records.length; for (var i = 0; i < length; i++) { var record = dataAdapter.records[i]; if (record.invoice_id== invoice_id) { records[records.length] = record; } } var dataSource = { datafields: dataFields, localdata: records } var adapter = new $.jqx.dataAdapter(dataSource); // update data source. $(\"#ordersGrid\").jqxGrid({ source: adapter }); }); $(\"#ordersGrid\").jqxGrid( { width: 900, height: 250, theme: theme, editable: true, keyboardnavigation: false, selectionmode: \'singlecell\', columns: [ { text: \'Item ID\', datafield: \'invoice_item_id\', width: 100 }, { text: \'Invoice ID\', datafield: \'invoice_id\', width: 150 }, { text: \'Description\', datafield: \'description\', width:150}, { text: \'From\', datafield: \'from_date\', width:100, columntype: \'datetimeinput\', cellsalign: \'right\', cellsformat: \'yyyy-MM-dd\', editable:true}, { text: \'To\', datafield: \'to_date\', width:100, columntype: \'datetimeinput\', cellsalign: \'right\', cellsformat: \'yyyy-MM-dd\', editable:true}, { text: \'Amount\', datafield: \'amount\', width: 150 } ] }); $(\"#ordersGrid\").jqxGrid(\'hidecolumn\', \'invoice_item_id\'); $(\"#customersGrid\").jqxGrid(\'selectrow\', 0); }); </script></head><body class=\'default\'> <div id=\'jqxWidget\' style=\"font-size: 13px; font-family: Verdana; float: left;\"> <h3> Invoice</h3> <div id=\"customersGrid\"> </div> <h3> Items</h3> <div id=\"ordersGrid\"> </div> </div></body></html>
What could be the problem?
Hello soonkoh,
The reason is that each time a row in the master grid is selected, the source of the details grid is set anew, as you may observe in the line:
$("#ordersGrid").jqxGrid({ source: adapter });
