jQuery UI Widgets Forums Grid Extract grid data. output as array or variable ?
This topic contains 3 replies, has 2 voices, and was last updated by  ivailo 9 years, 8 months ago.
  • ashwin prabhu
    I have extracted grid data with this code below:
    var data = \$("#jqxgrid").jqxGrid('exportdata', 'csv');
    If i did a console.log(data); to the above code, i get this as an output.
    "Order","Id","Comment"
    "6","12321","3rd test"
    is this data a variable and string ? it doesnot look like an array. 2nd thing- how can i convert this above data into an array.
    ashwin prabhu
    i am able to convert it into an array with this simple code
    var array = data.split(",");
    console.log(array);
    Please ignore this post guys. Thanks
    ashwin prabhu
    Pardon me, before you let this post go off.. i want one small help…
    There is a carriage return at the end of 2nd line. plus carriage returns for every row in my grid. How can i replace that carriage return with a comma ?
    i tried using regex but it didnt work. here is the code i tried using.
    data= data.replace(/\r/g,',');
    Instead of replacing carriage return (\r) with a comma (,) – it is giving me an error
    It says:
    Uncaught SyntaxError: Invalid regular expression: missing /
    ivailo
    Hi ashwin prabhu,
    Try data= data.replace(/(?:\r\n|\r|\n)/g, ‘,’);
    Here is the demo.
    Ivailo Ivanov
