jQuery UI Widgets Forums Grid Export jqxgrid data using ASP.net MVC C#
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 8 years, 10 months ago.
  • jetzky
    I am creating a project with ASP.net MVC 4 # with jqwidgets. I am trying to export via ajax but it won’t work. Here is my code.
    Controller:
    public void PotentialClientsReport(xportData data)
    var gridData = data.data;
    string path = @”Reports\Report” + “.xls”;
    if (gridData != null)
    System.IO.File.WriteAllText(Server.MapPath(path), gridData);
    Ajax:
    type: “POST”,
    url: “@Url.Action(“PotentialClientsReport”, “Reports”)”,
    success: function (data)
    data: {data:exportInfo},
    accept: ‘application/json’
    Thank you in advance.
    Hello jetzky,
    Did you try the solution provided in the NETExport folder of the jQWidgets source code download package? If not, please make sure you have read the file ReadMe.txt first. If it does not work on your side, please share if there are any errors thrown in your browser’s console or any other unexpected behaviour.
    We are looking forward to your answer.
