jQuery UI Widgets Forums Grid Event bubbling problem
This topic contains 4 replies, has 2 voices, and was last updated by  sushanth009 12 years, 9 months ago.
  • Event bubbling problem #5497
    sushanth009
    Hello Peter,
    I have two images in one of the columns of my grid. There is a check box which when selected selects all the checkboxes in the grid.
    Also there is a pdf imagewhich when clicked should open the pdf documents.
    But my problem here is I am handling this in the ‘columnclick’ event. So I need to accomplish independent tasks when clicked on the different images. but because of bubbling I am not able to do so.
    How can I accomplish calling different functions when clicking on different images. I tried using the click event for both the images, but that is not working and I had to use the columnclick event . Any insight on this will be helpful..
    Sushanth
    Event bubbling problem #5514
    Hi Sushanth,
    The event.target property provides the clicked HTML element. If you have multiple elements in a column, you can set a class or id to them and then check the event.target’s class or id and implement your logic depending on the clicked element in the ‘columnclick’ event.
    Event bubbling problem #5577
    sushanth009
    Hello Peter ,
    I tried using the event.target property but no matter where I click inside the div , the same functions were being called irrespective of where it was clicked.. Can you give me a small snippet of how this has to be done..
    There are two divs inside this column.. One div with class – pdf-image and second div with class checkbox-image.
    I want to call two different functions when clicked on each div…
     $('#grid').on("columnclick", function(event) {
    if (event.args.column.text == "dummyCheck") { // This makes sure columnClick works for only this column
    Doing this I saw that the event.target’s class was always being jqx-grid and other wrapper classes. To access the div in which the divs were I did this
     $tar = $(event.target.childNodes[1].childNodes[0].childNodes[1].childNodes[0].childNodes[0].childNodes[2].childNodes[0].childNodes[0].childNodes[0]);
    This gave me the div with pdf-image class div.
    I tried doing this but was of no use..
    $tar1 = $(event.target.childNodes[1].childNodes[0].childNodes[1].childNodes[0].childNodes[0].childNodes[2].childNodes[0].childNodes[0].childNodes[1]);
    if ($tar.is('div.pdf-image')) {
    alert('pdf Clicked');
    if ($tar1.is('div.checkbox-image')) {
    alert('Checkbox Clicked');
    But both functions are being called no matter where I clicked , because the condition what I wrote is always true..
    Can you help with out with this.
    Sushanth
    Event bubbling problem #5582
    Hi Sushanth,
    Here’s a different approach that selects the column elements and handles their click events.
    $("#jqxgrid").bind('bindingcomplete', function () {
    $("#jqxgrid .jqx-grid-column-header").bind('click', function (event) {
    // get click location.
    var y = event.pageY;
    var x = event.pageX;
    // get clicked HTML element.
    var target = event.target;
    $("#jqxgrid").jqxGrid(
    { text: 'Name', datafield: 'name', width: 250 },
    { text: 'Beverage Type', datafield: 'type', width: 250 },
    { text: 'Calories', datafield: 'calories', width: 180 },
    { text: 'Total Fat', datafield: 'totalfat', width: 120 },
    { text: 'Protein', datafield: 'protein', minwidth: 120 }
    Event bubbling problem #5622
    sushanth009
    It tried doing it but was not able to pin point the exact boundaries of it.
    Also once I made the iconscontainer class display:none , the click event seems to work.. I could handle the issue in that event itself.. Thanks for the input Peter.
    Sushanth
