jQuery UI Widgets Forums Grid error occurs when load grid again
This topic contains 15 replies, has 2 voices, and was last updated by  neha101288 9 years, 11 months ago.
Viewing 15 posts - 1 through 15 (of 16 total)
  • error occurs when load grid again #71519
    neha101288
    I got this <
    JavaScript runtime error: jqxGrid: The data is still loading. When the data binding is completed, the Grid raises the ‘bindingcomplete’ event. Call this function in the ‘bindingcomplete’ event handler.
    > error when i loaded my grid again,
    actually i need to display grid data on button click event, it works fine with first time but through the error second time(second time click on button.)
    error occurs when load grid again #71525
    Hi neha101288,
    This error is thrown, because, as the message states, the data is still loading and you are trying to load it a second time before the first load has been complete. As a workaround, you can use a flag variable, e.g.:
    var loading = false;
    $('#button').click(function() {
        if (loading === false) {
            loading = true;
            // place your code for data loading here
    $('#jqxGrid').on('bindingcomplete', function(event) {
        loading = false;
    error occurs when load grid again #71610
    neha101288
    I still have this error, bindingcomplete event fire correctly and when grid going to bind it through this error message.
    <0x800a139e – JavaScript runtime error: jqxGrid: The data is still loading. When the data binding is completed, the Grid raises the ‘bindingcomplete’ event. Call this function in the ‘bindingcomplete’ event handler.>
    Used this code in mvc and bind the grid from controller data is in json format.
    error occurs when load grid again #71618
    neha101288
    Actually got this in jqxgrid.sort.js file.
    sortby:function(d,g,f,e,b){if(this._loading&&b!==false)
    Column number – 3813
    error occurs when load grid again #71625
    Hi neha101288,
    Did you implement our flag variable solution?
    error occurs when load grid again #71627
    neha101288
    Hi Dimitar,
    Yes,i implement that solution and its work fine. bindingcomplete event fire correctly but when grid going to bind again(second time on button click) it through this error message.
    error occurs when load grid again #71628
    Hi neha101288,
    If the grid is still binding, the second button click should not do anything. That is what the flag variable is for. Please share your button click code and we will review if you have implemented the solution correctly.
    error occurs when load grid again #71629
    neha101288
    Hi Dimitar,
    Thanks for your fast reply,This is my code
    $(‘#jqxgrid’).on(‘bindingcomplete’, function (event) {
    loading = false;
    alert(“Binding is completed”);
    $(“#viewReport”).click(function () {
    debugger;
    loading = true;
    $(‘#ReportTitle’).empty();
    $(‘#ReportTitle’).append(‘<h2><div style=”margin-top: 5px;”>Auditee Report <br/>’ + yearMonthFromVal + ‘-‘ + yearMonthThruVal + ‘<br/>Errors</div><h2>’);
    var AuditeeErrorResult =
    cache: false,
    { name: ‘Auditee’ },
    { name: ‘ErrorCount’ },
    { name: ‘FunctionDesc’ },
    { name: ‘FunctionErrorCode’ },
    { name: ‘FunctionErrorDesc’ },
    { name: ‘FunctionGroupDesc’ }
    url: ‘../Auditee/GetAuditeeErrorJson’,
    data: { yearMonthFrom: yearMonthFromVal, yearMonthThru: yearMonthThruVal, auditeeIdList: checkedItems },
    var dataError = new $.jqx.dataAdapter(AuditeeErrorResult, {
    loadComplete: function () {
    $(“#jqxgrid”).jqxGrid(‘expandallgroups’);
    $(“#jqxgrid”).jqxGrid(‘showgroupsheader’, false);
    $(“#jqxgrid”).jqxGrid(‘autoresizecolumns’);
    $(“#jqxgrid”).on(‘pagechanged’, function () {
    $(“#jqxgrid”).jqxGrid( // error occurs here in second time of button click event.
    width: 1200,
    source: dataError,
    theme: ‘darkblue’,
    altrows: true,
    enabletooltips: true,
    groupable: true,
    pageSize: 10,
    ready: function () {
    pagesizeoptions: [’10’, ’20’, ’30’, ’40’, ’50’],
    { text: ‘Auditee’, dataField: ‘Auditee’, width: 200 },
    { text: ‘Error Count’, dataField: ‘ErrorCount’, width: 200 },
    { text: ‘Function Group’, dataField: ‘FunctionGroupDesc’, width: 160 },
    { text: ‘Function’, dataField: ‘FunctionDesc’, width: 220 },
    { text: ‘Error Code’, dataField: ‘FunctionErrorCode’, width: 120 },
    { text: ‘Error Description’, dataField: ‘FunctionErrorDesc’ }
    groups: [‘Auditee’]
    error occurs when load grid again #71648
    Hi neha101288,
    You should call the grid initialization code only once. On each button click you just need to update the data. Here are the changes I suggest you make:
    var AuditeeErrorResult = {
        cache: false,
        datafields: [{
        url: '../Auditee/GetAuditeeErrorJson',
        data: {
    var dataError = new $.jqx.dataAdapter(AuditeeErrorResult);
    var loading = true;
    $('#jqxgrid').on('bindingcomplete', function(event) {
        loading = false;
        alert("Binding is completed");
        $("#jqxgrid").jqxGrid('expandallgroups');
        $("#jqxgrid").jqxGrid('showgroupsheader', false);
        $("#jqxgrid").jqxGrid('autoresizecolumns');
    $("#jqxgrid").jqxGrid({
        width: 1200,
        source: dataError,
        theme: 'darkblue',
        altrows: true,
        groupable: true,
        pageSize: 10,
        pagesizeoptions: ['10', '20', '30', '40', '50'],
        columns: [{
                text: 'Auditee',
                dataField: 'Auditee',
                width: 200
                text: 'Error Count',
                dataField: 'ErrorCount',
                width: 200
                text: 'Function Group',
                dataField: 'FunctionGroupDesc',
                width: 160
                text: 'Function',
                dataField: 'FunctionDesc',
                width: 220
                text: 'Error Code',
                dataField: 'FunctionErrorCode',
                width: 120
                text: 'Error Description',
                dataField: 'FunctionErrorDesc'
        groups: ['Auditee']
    $("#jqxgrid").on('pagechanged', function() {
    $("#viewReport").click(function() {
            loading = true;
            $('#ReportTitle').empty();
            $('#ReportTitle').append('<h2><div style="margin-top: 5px;">Auditee Report <br/>' + yearMonthFromVal + '-' + yearMonthThruVal + '<br/>Errors</div><h2>');
                cache: false,
                datafields: [{
                data: {
            dataError.dataBind();
            $("#jqxgrid").jqxGrid('updatebounddata');
    error occurs when load grid again #71696
    neha101288
    Hi Dimitar,
    Now getting this error “Unable to get property ‘data Bind’ of undefined or null reference jqwidget”.How to solve this.
    error occurs when load grid again #71704
    neha101288
    hi Dimitar,
    I made change, but on grid data update grid bind with my previous parameter.i did not resolve this.
    error occurs when load grid again #71712
    Hi neha101288,
    I thought the values of yearMonthFromVal, yearMonthThruVal and checkedItems are updated by the time you click the button (in a portion of your code you did not share). Is that not so?
    error occurs when load grid again #71713
    neha101288
    Hi Dimitar,
    I am sharing my full code here, please check it
    ///My Code
    Layout = “~/Views/Shared/_ReportLayout.cshtml”;
    @section scripts {
    debugger;
    var yearMonthFromVal = 0;
    var yearMonthThruVal = 0;
    var auditeeIdListVal = null;
    var checkedItems = null;
    //Prepare Source
    { name: ‘YearMonth’ },
    { name: ‘YearMonthDesc’ }
    url: ‘../Auditee/GetReport’
    //Bind Year Month DropDownList
    var dataAdapter1 = new $.jqx.dataAdapter(source);
    $(“.jqxWidget”).jqxDropDownList({
    selectedIndex: 0, source: dataAdapter1, displayMember: “YearMonthDesc”, valueMember: “YearMonth”, width: 200, height: 20, theme: ‘energyblue’
    //check all
    $(“#CheckAll”).jqxButton({
    theme: ‘energyblue’, width: ’80’, theme: ‘energyblue’
    $(‘#CheckAll’).on(‘click’, function () {
    $(“.jqxWidget1”).jqxDropDownList(‘checkAll’);
    //Print Button
    $(“#print”).jqxButton({ theme: ‘energyblue’});
    $(“#print”).click(function () {
    var gridContent = $(“#jqxgrid”).jqxGrid(‘exportdata’, ‘html’);
    var newWindow = window.open(”, ”, ‘width=800, height=500’),
    document = newWindow.document.open(),
    pageContent =
    ‘<!DOCTYPE html>\n’ +
    ‘<html>\n’ +
    ‘<head>\n’ +
    ‘<meta charset=”utf-8″ />\n’ +
    ‘<title>jQWidgets Grid</title>\n’ +
    ‘</head>\n’ +
    ‘<body>\n’ + gridContent + ‘\n</body>\n</html>’;
    document.write(pageContent);
    document.close();
    newWindow.print();
    // Create a Export jqxDropDownList
    var download = [
    “Export”,
    “XML”,
    “CSV”,
    “PDF”,
    “Excel”
    $(“#ddlExport”).jqxDropDownList({
    source: download, selectedIndex: 0, width: 80, height: 20, theme: ‘darkblue’
    //Code for export page
    $(‘#ddlExport’).on(‘change’, function (event) {
    var args = event.args;
    var index = args.index;
    switch (index) {
    case 1: $(“#jqxgrid”).jqxGrid(‘exportdata’, ‘xml’, ‘Auditee_Error_Report’);
    break;
    case 2: $(“#jqxgrid”).jqxGrid(‘exportdata’, ‘csv’, ‘Auditee_Error_Report’);
    break;
    case 3: $(“#jqxgrid”).jqxGrid(‘exportdata’, ‘pdf’, ‘Auditee_Error_Report’);
    break;
    case 4: $(“#jqxgrid”).jqxGrid(‘exportdata’, ‘xls’, ‘Auditee_Error_Report’);
    break;
    //From Month DropDown Text Change Event
    var dataAdapter1 = new $.jqx.dataAdapter(AuditeeName);
    $(‘#DropDownListFromMonth’).on(‘change’, function (event) {
    yearMonthFromVal = $(‘#DropDownListFromMonth’).jqxDropDownList(‘getItem’, args.index).value;
    GetAuditeeName(yearMonthFromVal, yearMonthThruVal);
    //To Month DropDown Text Change Event
    $(‘#DropDownListToMonths’).on(‘change’, function (event) {
    yearMonthThruVal = $(‘#DropDownListToMonths’).jqxDropDownList(‘getItem’, args.index).value;
    //Check Change event of Auditee name drop down
    $(“#AuditeeName”).on(‘checkChange’, function (event) {
    if (event.args) {
    var item = event.args.item;
    if (item) {
    var items = $(“#AuditeeName”).jqxDropDownList(‘getCheckedItems’);
    checkedItems = “”;
    $.each(items, function (index) {
    checkedItems += this.value + “, “;
    cache: false,
    datafields: [{
    data: {
    var dataAdapter = new $.jqx.dataAdapter(AuditeeErrorResult);
    //dataError.dataBind();
    loading = false;
    $(“#jqxgrid”).jqxGrid({
    width: 1200,
    theme: ‘darkblue’,
    altrows: true,
    groupable: true,
    pageSize: 10,
    columns: [{
    text: ‘Auditee’,
    width: 200
    width: 200
    width: 160
    text: ‘Function’,
    width: 220
    text: ‘Error Code’,
    width: 120
    groups: [‘Auditee’]
    //view Report Click event
    loading = false;
    $(“#viewReport”).jqxButton({ width: ’90’, theme: ‘darkblue’ });
    debugger;
    loading = true;
    cache: false,
    datafields: [{
    data: {
    //dataAdapter = new $.jqx.dataAdapter(AuditeeErrorResult);
    dataAdapter.dataBind();
    $(“#jqxgrid”).jqxGrid(‘updatebounddata’);
    //Function to bind Auditee name dropdown
    function GetAuditeeName(yearMonthFromValT, yearMonthThruValT) {
    var AuditeeName =
    { name: ‘AuditeeID’ },
    { name: ‘Auditee’ }
    url: ‘../Auditee/GetAuditeeNameJson’,
    data: { yearMonthFrom: yearMonthFromValT, yearMonthThru: yearMonthThruValT }
    $(“.jqxWidget1”).jqxDropDownList({
    checkboxes: true, source: dataAdapter1, displayMember: “Auditee”, valueMember: “AuditeeID”, width: 200, height: 20, theme: ‘energyblue’
    $(“.jqxWidget1″).jqxDropDownList(‘checkIndex’, 0);
    <body class=’default’>
    <div id=’content’ style=”background-color: white; width: 100%; padding: 10px; height: 800px”>
    <table style=”width: 100%”>
    <tr>
    <td>
    <h1>Report</h1>
    </td>
    </tr>
    <tr>
    <td>
    <table style=”border: solid; border-color: darkgrey” width=”90%”>
    <tr>
    <td>
    <br />
    </td>
    <td>
    <br />
    </td><td>
    <br />
    </td><td>
    <br />
    </td>
    </tr>
    <tr>
    <td width=”25%”><b>YearMonth From:</b></td>
    <td width=”25%”>
    <div id=’DropDownListFromMonth’ class=”jqxWidget”>
    </td>
    <td width=”25%”>
    <b>YearMonth Thru:</b>
    </td>
    <td width=”25%”>
    <div id=’DropDownListToMonths’ class=”jqxWidget”>
    </td>
    </tr>
    <tr>
    <td width=”25%”><b>Auditee Name:</b></td>
    <td width=”25%”>
    <div id=’AuditeeName’ class=”jqxWidget1″>
    </td>
    <td width=”25%”>
    <input type=”button” id=’CheckAll’ value=”Check all” />
    <input type=”button” value=”View Report” id=’viewReport’ />
    </td>
    <td width=”25%”></td>
    </tr>
    <tr>
    <td width=”25%”>
    </td>
    <td>
    <div id=”ddlExport”></div>
    </td>
    <td width=”25%”>
    <input type=”button” value=”Print” id=’print’ />
    </td>
    <td width=”25%”>
    </td>
    </tr>
    </table>
    </td>
    </tr>
    <tr>
    <td>
    <br />
    </td>
    </tr>
    <tr>
    <td>
    <br />
    <tr>
    <td>
    <b>
    <div id=”ReportTitle”></div>
    </b>
    </td>
    </tr>
    <tr>
    <td></td>
    </tr>
    <tr>
    <td>
    <br />
    <div id=”jqxgrid”></div>
    </td>
    </tr>
    </table>
    </td>
    </tr>
    </table>
    </div></body>
    error occurs when load grid again #71723
    neha101288
    Hi Dimitar,
    I have checked by using this code(given in my previous reply),my code hits two times server.with initial value. i can not understand why it is happening.
    error occurs when load grid again #71758
    neha101288
    Hi dimitar,
    I think this could be solve by using dynamic parameter(pass with datadapter),please tell me how to pass dynamic parameter.
