jQuery UI Widgets Forums Grid enter focus problem textarea in jqxGrid
This topic contains 2 replies, has 2 voices, and was last updated by  devsim 4 years, 11 months ago.
  • devsim
    Hello
    My English is poor. n_n;;;;;
    I saw the issue
    https://www.jqwidgets.com/community/topic/overriding-enter-key-in-textarea-of-editable-jqx-grid/
    Hristo’s answer
    Here is example in textArea
    apple
    bro
    camera
    1. When I located curser last the apple
    apple_
    bro
    camera
    2. Press Enter key, curser located bottom of camera
    apple
    bro
    camera
    _
    3. I think cause of this Code -> ‘ currentContent = editorElement.val() + \n ‘
    so. how do I solved the problem ?
    I Want like this
    apple
    _
    bro
    camera
    thanks
    Hi devsim,
    Thank you for using jQWidgets Grid.
    You can use the editorElement.focus() to put the focus to the first character in the editor.
    devsim
    After 11 months later
    I solved the problem myself.
    This is My solution
    var editorElement = null;
    var currentContent = ”;
    $(“#devsimGrid”).jqxGrid({
    handlekeyboardnavigation: function (event) {
    var key = event.charCode ? event.charCode : event.keyCode ? event.keyCode : 0;
    if (key == 13) {
    var txtArea = editorElement[0];
    var txtValue = txtArea.value;
    var selectPos = txtArea.selectionStart;
    var beforeTxt = txtValue.substring(0, selectPos);
    var afterTxt = txtValue.substring(txtArea.selectionEnd, txtValue.length);
    currentContent = beforeTxt + “\n” + afterTxt;
    editorElement.val(currentContent);
    var pos = (selectPos+1);
    var obj = document.getElementById(“customTextArea0TextArea”);
    if (obj.setSelectionRange) {
    obj.focus();
    obj.setSelectionRange(pos, pos);
    else if (obj.createTextRange) {
    var c = obj.crateTextRange();
    c.move(“character”, pos);
    c.select();
    return true;
    } else if (key == 27) {
    return true;
    text: ‘Work’,
    datafield: ‘Work’,
    width: ‘380px’,
    align: ‘center’,
    cellsrenderer: textrenderer,
    columntype: ‘template’,
    createeditor: function(row, cellvalue, editor, celltext, cellwidth, cellheight) {
    editorElement = $(‘<textarea id=”customTextArea’ + row + ‘”></textarea>’).prependTo(editor);
    editorElement.jqxTextArea({
    height: 88,
    width: ‘100%’
    initeditor: function (row, cellvalue, editor, celltext, pressedChar) {
    currentContent = ”;
    editorElement.val(cellvalue);
    geteditorvalue: function (row, cellvalue, editor) {
    return editor.find(‘textarea’).val();
