jQuery UI Widgets Forums Grid Edit mode issues with wrapped cells
This topic contains 2 replies, has 2 voices, and was last updated by  Dimitar 10 years, 11 months ago.
  • MaxWell
    Good day!
    I’m new jqWidjets user. And first of all let me say that this framework is very impressive. Thanks a lot to authors.
    But I have some trubles:
    1. If I try to edit a multiline (wrapped) cells, then a row shrinks and it looks ugly.
    Try to click on column 2 cell to reproduce:
    	var data = [{ '1': 'Short','2': 'Long sentence to wrap it by two or more lines'}];
    		localdata: data,
    	$("#jqxgrid").jqxGrid(
    		autorowheight: true,
    			{ text: 'Column 1', datafield: '1', width:70 },
    			{ text: 'Column 2', datafield: '2', width:70 },
    2. In second example edit mode can not activates by clicking on column 2 cell:
    		localdata: data,
    May be something I doing is wrong. Help please.
    MaxWell
    Sorry I forgot to say that jQWidgets v3.3.0 is used.
    Hello MaxWell,
    Unfortunately, the autorowheight setting does not work when a cell has entered edit mode. This issue will be fixed in the next version of jQWidgets, expected in mid-June. You can use pop-up editing as a workaround until then.
