jQuery UI Widgets › Forums › Grid › Dynamic grid problem
Tagged: gridview, javascript grid, jquery grid control
This topic contains 7 replies, has 2 voices, and was last updated by Peter Stoev 10 years, 1 month ago.
AuthorDynamic grid problem Posts
Dear Sir,
I am getting an error like-
Invalid Selector – #jqxgrid! Please, check whether the used ID or CSS Class name is correct.
When i load grid with partial view at runtime,after loading grid when i enter the data on grid we want to disable or enable grid it throw following error:-
And if i put the grid on view and not using partial view it works fine.And i also viewed the html of grid both are same but dynamic grid with partial view loading grid throws an error.I also check $(“#jqxgrid”).length it’s output always zero in case of partial view.
Please suggest me some solution as soon as possible.Thanks & Regards,
Vipin KumarHi Vipin Kumar,
Invalid Selector is raised when your jQuery Selection is invalid i.e you try to create Grid from HTML Element which does not exist.
http://www.jqwidgets.comDear Sir,
Please suggest me if i want to load grid dynamically in jquery with partialview or any other alternate in MVC.
Thanks & Regards,
You should have HTML DIV tag with valid ID to create a Grid. If you wish add that DIV tag dynamically using jQuery – append, prepend methods or other approach.
I am using jqxtabcontrol and add tabs dynamically and when i click on add tab button new tab is created and a partialview will be added in that tab.
And user create dynamically as much they want.Please tell me what is the option to append,prepend method while using jqxtabcontrol with partialview (loading using jquery return html) and add in the tab like:-var data1;//here data1 is the html of partial view load using jquery
$(‘#jqxTabs’).jqxTabs(‘addLast’, ‘Sale Bill Tab’, data1);
$(‘#jqxTabs’).jqxTabs(‘ensureVisible’, -1);Thanks & Regards,
Vipin KumarHi Vipin,
See: http://api.jquery.com/append/
Now,i am using append method to add in tab but still same error.
Thanks & Regards,
If you add DIV tag with ID, you will not get jQurey Invalid Selector if your jQuery selector by ID is Correct i.e $(“#myID”).length > 0
