jQuery UI Widgets › Forums › Lists › DropDownList › Dropdownlist ‘val’ & ‘selectItem’ not working
This topic contains 1 reply, has 2 voices, and was last updated by Peter Stoev 12 years, 2 months ago.
I am not using ‘selectedIndex’ here, because I want to select the list based on the value or label. I am trying to implement the code, but it is not working. Am I doing something wrong?
<!DOCTYPE html> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <meta name="keywords" content="jQuery DropDownList, List, DropDownList, Popup List, jqxDropDownList, jqxListBox, List Widget, ListBox Widget, DropDownList Widget" /> <meta name="description" content="In this demo the ComboBox is bound to JSON data" /> <title id='Description'>In this demo the DropDownList is bound to JSON data.</title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript" src="../../scripts/jquery-1.8.1.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> </head> <body> <div id='content'> <script type="text/javascript"> $(document).ready(function () { var theme = getTheme(); var url = "../sampledata/customers.txt"; // prepare the data var source = { datatype: "json", datafields: [ { name: 'CompanyName' }, { name: 'ContactName' } ], id: 'id', url: url, async: false }; var dataAdapter = new $.jqx.dataAdapter(source); // Create a jqxDropDownList $("#jqxWidget").jqxDropDownList({ source: dataAdapter, displayMember: "ContactName", valueMember: "CompanyName", width: 200, height: 25, theme: theme }); $("#jqxWidget").jqxDropDownList('val', 'Alfreds Futterkiste'); // OR $("#jqxWidget").jqxDropDownList('selectItem', 'Ann Devon'); }); </script> <div id='jqxWidget'></div> </div> </body> </html>
Aravind MSHi Aravind,
1. The ‘selectItem’ method expects an “item” not a “String”. You should pass an “item” object. You can get an item by using “getItemByValue” or “getItem” methods. For more information, please visit: jquery-dropdownlist-api.htm.
2. ‘val’ gets or sets the displayed content in the content field.
