jQuery UI Widgets Forums Lists DropDownList Dropdownlist filter does not allow spaces
This topic contains 1 reply, has 2 voices, and was last updated by  Martin 4 years, 10 months ago.
  • ryukend
    My code is the following:
    				{ name: 'ID'},
    				{ name: 'cliente', type: 'string'},
    				url: '<?php echo base_url();?>gestion/traer_clientes',
    				async: false
    			$("#dropdownlist").jqxDropDownList(
    				filterPlaceHolder: "Buscar por razon social..",
    				placeHolder: "Seleccionar cliente...",
    				theme: 'metro',
    				width: '100%',
    				height: 34,
    				selectedIndex: -1,
    				displayMember: 'cliente',
    				valueMember: 'ID'
    When I try to filter and place a space it does not allow it, what can it be ?, thanks
    Martin
    Hello ryukend,
    What do you mean that if does not allow you to place a space?
    I have tested the following Example and it is working fine.
    Martin Yotov
    https://www.jqwidgets.com
