jQuery UI Widgets › Forums › Plugins › Validator, Drag & Drop, Sortable › Drag Drop Between Splitter Panels
Tagged: between, drag, drop, jqxdragdrop, jqxsplitter, overflow, panel, splitter
This topic contains 4 replies, has 2 voices, and was last updated by jqwidgetsdev 10 years, 8 months ago.
Hello.
I was wondering if there is support to drag & drop a DIV elements between two jqxSplitter panels?
If at all possible able to point me to an example on how this could be accomplished?
Thanks.
Hello jqwidgetsdev,
This can be achieved but you need to set the splitter panels’ overflow to visible. Here is an example:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html lang="en"> <head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.summer.css" type="text/css" /> <style type="text/css"> .jqx-splitter-panel { overflow: visible; } </style> <script type="text/javascript" src="../../scripts/jquery-1.10.2.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxsplitter.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdragdrop.js"></script> </head> <body> <div id='content'> <script type="text/javascript"> $(document).ready(function () { $("#jqxSplitter").jqxSplitter({ theme: 'summer', panels: [{ size: '100px'}] }); $("#dragMe").jqxDragDrop(); }); </script> <div id='jqxSplitter' style="width: 300px; height: 150px; background-color: #FFFFAF"> <div style="background-color: #97FFAF"> </div> <div style="background-color: #E8C0AF"> <div id="dragMe" style="width: 50px; height: 50px; background: teal; z-index: 999999;"> </div> </div> </div> </div> </body> </html>
http://www.jqwidgets.com/Hello Dimitar.
Thanks for your reply. I tried your example, when I drag the “dragMe” DIV and release it in the left DIV of the jqxSplitter, the “dragMe” DIV completely vanishes. I was expecting the DIV to “stick” at the location in the left DIV. Why doesn’t it?
What kind of method does jqWidgets have to make the “dragMe” DIV “stick” where the DIV was released?
Thanks for your help.
Hi jqwidgetsdev,
The dragMe div stays after being dropped when we test the example. Are you sure you are using the latest version of jQWidgets (3.4.0) and that you have set
overflow: visible
to the class jqx-splitter-panel?Best Regards,
I confirm the issue is resolved.
Thank you!
