jQuery UI Widgets › Forums › Navigation › Expander › Doesn't work with "box-sizing: border-box;"
This topic contains 3 replies, has 2 voices, and was last updated by Peter Stoev 12 years, 2 months ago.
The expander doesn’t display well if I do the following in my css.
* { -moz-box-sizing: border-box; -webkit-box-sizing: border-box; box-sizing: border-box; }The clickable area is wider then the content area.
Kind regards
Hi NoiZy,
The following sample is built with jQWidgets 2.7 and we cannot reproduce the reported behavior.
<!DOCTYPE html><html lang="en"><head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript" src="../../scripts/jquery-1.8.2.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxexpander.js"></script> <style> * { -moz-box-sizing: border-box; -webkit-box-sizing: border-box; box-sizing: border-box; } </style> <script type="text/javascript"> $(document).ready(function () { // Create jqxExpander var theme = getDemoTheme(); $("#jqxExpander").jqxExpander({ width: '350px', theme: theme }); }); </script></head><body class='default'> <div id='jqxWidget' style="float: left;"> <div id='jqxExpander'> <div> Early History of the Internet</div> <div> <ul> <li>1961 First packet-switching papers</li> <li>1966 Merit Network founded</li> <li>1966 ARPANET planning starts</li> <li>1969 ARPANET carries its first packets</li> <li>1970 Mark I network at NPL (UK)</li> <li>1970 Network Information Center (NIC)</li> <li>1971 Merit Network's packet-switched network operational</li> <li>1971 Tymnet packet-switched network</li> <li>1972 Internet Assigned Numbers Authority (IANA) established</li> <li>1973 CYCLADES network demonstrated</li> <li>1974 Telenet packet-switched network</li> <li>1976 X.25 protocol approved</li> <li>1979 Internet Activities Board (IAB)</li> <li>1980 USENET news using UUCP</li> <li>1980 Ethernet standard introduced</li> <li>1981 BITNET established</li> </ul> </div> </div> </div></body></html>
http://www.jqwidgets.comTo be honest, I’m a littlebit frustrated about jqWidgets.
It’s again a 100% page scenario, were I already make several bug reports for other components in jqWidgets.
I don’t know, if this time, there is a relation between 100% and my problem.I know there is a problem with jqWidgets in a 100% page scenario, but I can not pin the problem to one line of code for you ;(
And If I do a screenshot of the problem and add it to a topic in this forum, you delete it.I only know I ever use the same “framework” around a web project.
I use normalize.css, modernizr and the line I already mentioned in my general css file.And I know, I have ever design problems with jqWigets which is realy frustrating!
Kind regards
Hi Noizy,
Thank you for the feedback.
In case we reproduce the reported behavior, we will fix it. At present, there is a known issue in jqxExpander and jqxNavigationBar if the width property is a percentage value and it will be resolved next version. However, I do not know whether this is related to your issue, because you have not provided any sample code.
