jQuery UI Widgets › Forums › Editors › Editor › Does it work on jqxWindow popup
This topic contains 4 replies, has 3 voices, and was last updated by Peter Stoev 10 years, 6 months ago.
Hi.
I have been facing problem in implementing the jQxEditor in the jqxWindow. Does it work there? I have coded it righly.
Please help me.Hi abhijeetchindhe,
Yes of course. Our jqxEditor widget works perfectly fine in jqxWindow. It does not really matter whether it is in jqxWindow or not. Just make sure that all the required references are correct and that the widget is initialized in the way it should be.
Working Example:
<!DOCTYPE html> <html lang="en"> <head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.10.2.min.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxwindow.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxeditor.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownbutton.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript"> function createElements() { $('#w').jqxWindow({ width: 900, height: 400, maxWidth: 1000, resizable: false, isModal: true, modalOpacity: 0.3, initContent: function () { $("#editor").jqxEditor({ width: '100%', height: '100%' }); } }); } $(document).ready(function () { createElements(); }); </script> </head> <body class='default'> <div id="w"> <div> Window </div> <div> <div id="editor"></div> </div> </div> </body> </html>
http://www.jqwidgets.comI have found an example when the editor doesn’t work
If you set autoopen: false the editor don’t work correctly
view example here
http://jsfiddle.net/q2xtsut4/PS: only if you have another layer (example Tabs) between window and editor
Hi hexstudy,
The widget is not created correctly in your sample and that’s why it would not work.
1. Widgets inside jqxTabs should be initialized within the initTabContent function.
2. Widgets inside jqxWindow should be initialized within the jqxWindow’s initContent function.Both of the above are missing in your code and that’s why widgets will not work.
