jQuery UI Widgets Forums Grid Does 'ensurerowvisible' work with grouped rows?
This topic contains 3 replies, has 2 voices, and was last updated by  alastairwalker 9 years, 2 months ago.
  • alastairwalker
    I am using a groups rows situation, with three levels of grouping.
    I have found that the method ‘ensurerowvisible’ works well with ‘groupable’ set to false (i.e. inactive).
    If ‘groupable’ is set to true (and a couple of groups set up), then the ‘ensurerowvisible’ method seems to have no effect on adjusting the sidebar to make the selected row visible.
    Do you have any guidance or remarks on this?
    Alastair
    alastairwalker
    Oops! Wrong category – should be under ‘Grid’!
    Admin – can you move this topic to Grid?
    Alastair
    ivailo
    Hi alastairwalker,
    ‘ensurerowvisible’ method works well with grouped rows.
    Probably you are confused cause after grouping the rows are reorganized and your row is in group in visible area.
    That make it “visible” for this method(if it’s parent groups are collapsed and visible).
    For example try this demo.
    When you click the button, probably nothing will happen, cause the row 500 is in visible group.
    So try to expand some groups and again click the button. ‘ensurerowvisible’ will scroll to the correct position.
    Ivailo Ivanov
    alastairwalker
    That is very helpful! It solved my problem.
    Thank you very much!
    Alastair
