jQuery UI Widgets Forums Grid Display JSON data in a grid using dynamic column names?
This topic contains 2 replies, has 2 voices, and was last updated by  Dimitar 11 years, 6 months ago.
  • realtek
    I have a JSON output which displays what I would like to use as the “Column Name” and also the data inside it.
    How can I use the dataAdapter/source to use the JSON field name as the actual grid column name rather than hard coding it on the grid?
    Thanks!
    realtek
    Here is my code from the Grid I currently have, (hope its ok) – Basically, my JSON is built automatically from PHP json_encode. It will provide a list of columns and then the data which will always fit in the same columns sequentially.
    var url = "json/mainGrid.php"
    var source = {
    datatype: 'json',
    url: url,
    root: 'rowsinfo',
    cache: false,
    columns:[],
    var columnsdata = new Array();
    for (k in data.columnsinfo){
    var col=[];
    col.text = data.columnsinfo[k]["DISPLAYNAME"];
    col.datafield = data.columnsinfo[k]["FIELDNAME"];
    columnsdata.push(col);
    source.columns = columnsdata;
    $("#jqxgrid").jqxGrid({columns : source.columns});
    data: {
    startcolumn: 1,
    Here is an example of my JSON Output (which could be wrong)
    {"columnsinfo":{"FIELDNAME":"SEQUENCE","DISPLAYNAME":"Test #"}}{"rowsinfo":{"Test #":"1"}}
    Hello realtek,
    Please refer to the forum topic Need to create grid columns dynamically from JSON for some tips on this matter.
