jQuery UI Widgets Forums Grid Design flaw ? not possible to implement Nested Grid with Drag-drop
This topic contains 9 replies, has 2 voices, and was last updated by  Keshavan 9 years, 10 months ago.
  • Keshavan
    I tried implementing Nested grid with drag drop feature, (Nested grid and another grid from which I tried to drag drop in to inner grid of nested grid).
    I checked and found inner grid’s ID starts with grid0, grid1, …. gridn accordingly depending on the row of outer grid of the nested grid.
    I have taken care for the same using a variable ‘referencerow’ which I properly update based on nested grid’s Outer grid.
                                 var grid = "grid" + referencerow;
                                  cell = $("#grid").jqxGrid('getcellatposition', position.left, position.top);
    But drop doesn’t happen. below is my full code.
    Please let me know if drag and drop with nested grid is not possible to implement, please suggest solution.
    Keshavan
        <title id='Description'>
            In order to enter in edit mode, click any of the 'Edit' buttons. To save the changes, click the 'Save' button in the popup dialog. To cancel the changes
            click the 'Cancel' button in the popup dialog.
        </title>
        <link rel="stylesrIdheet" href="/Content/Site.css" type="text/css" />
        <link rel="stylesheet" href="/jqWidgets/jqwidgets/styles/jqx.base.css" type="text/css" />
        <link rel="stylesheet" href="/jqWidgets/jqwidgets/styles/jqx.ui-sunny.css" type="text/css" />
        <link rel="stylesheet" href="/jqWidgets/jqwidgets/styles/jqx.fresh.css" type="text/css" />
        <script type="text/javascript" src="/JqWidgets/scripts/jquery-1.11.1.min.js"></script>
        <script type="text/javascript" src="/JqWidgets/scripts/check_browser_close.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxcore.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxdata.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxbuttons.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxscrollbar.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxmenu.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.selection.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.filter.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.sort.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxwindow.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxlistbox.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxselection.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.grouping.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.aggregates.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.columnsresize.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.columnsreorder.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxgrid.edit.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxnumberinput.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxdropdownlist.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxinput.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxdatetimeinput.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/globalization/globalize.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxcalendar.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxdragdrop.js"></script>
        <script type="text/javascript" src="/JqWidgets/jqwidgets/jqxcheckbox.js"></script>
            var refGrid;
                var gid1 = gid2 = quantity = sellprice = psquantity = Tamt = Tqty = rqty = ctr = ref = ref1 = order_id = id = rowcount = mode = 0;
                var gid3 = 1;
                var data = {};
                var cartItems = [];
                var valueDesc = " ";
                var arowid = [];
                var jsonString1 = new Array();
                var jsonString2 = [];
                var theme = "ui-sunny";
                var url = "/Ship/GetOrders";
                var urunId, oid, odid, refoid, invqty, refpsq, refsq, Rcell, desc, rselect, datarow, pid, cid, refdata, pc;
                var orderstatus = "Shipment Pending";
                var grid;
                var referencerow = 0;
                var generaterow = function (id) {
                    var row = {};
                    row["OrderId"] = id;
                    row["CustomerId"];
                    row["OrderDate"];
                    row["OrderAmount"];
                    row["OrderStatus"];
                    return row;
                var shipurl = "/Ship/GetShips";
                var shipSource =
    					{ name: 'ShipId' },
    					{ name: 'OrderId' },
    					{ name: 'ProductCode' },
                        { name: 'ProductDesc' },
    					{ name: 'OrderQty' },
                        { name: 'PendingShipQty' },
                        { name: 'ShipQty' },
                        { name: 'ShipDate', type: 'datetime' },
    					{ name: 'OrderDetailId' },
                        { name: 'ShipStatus' },
                        { name: 'Notes' },
                        { name: 'Cancelled' },
                    url: shipurl,
                    async: false
                var shipDataAdapter = new $.jqx.dataAdapter(shipSource);
                Ships = shipDataAdapter.records;
                // create nested grid.
                var initrowdetails = function (index, parentElement, gridElement, record) {
                    var id = record.uid.toString();
                    grid = $($(parentElement).children()[0]);
                    var filter_or_operator = 1;
                    var filtervalue = id;
                    var filtercondition = 'equal';
                    var filter = filtergroup.createfilter('stringfilter', filtervalue, filtercondition);
                    // fill the orders depending on the id.
                    var shipssbyid = [];
                    for (var m = 0; m < Ships.length; m++) {
                        var result = filter.evaluate(Ships[m]["OrderId"]);
                        if (result)
                            shipssbyid.push(Ships[m]);
                        var row = {};
                        row["ShipId"];
                        row["Notes"] = " ";
                        row["ProductCode"];
                        row["ProductDesc"];
                        row["OrderQty"];
                        row["PendingShipQty"];
                        row["ShipQty"] = 0;
                        row["ShipDate"];
                        row["OrderDetailId"];
                        row["ShipStatus"] = false;
                        row["Cancelled"];
                        return row;
                    var shipsource = {
                            { name: 'ShipId' },
                            { name: 'Notes' },
                            { name: 'ShipDate', type: 'date' },
                            { name: "ShipStatus" },
                            { name: "Cancelled" },
                        localdata: shipssbyid
                    if (grid != null) {
                        grid.jqxGrid({
                            source: shipsource, theme: 'fresh', width: 870, height: 150,
                            width: 900,
                            showstatusbar: true,
                            columnsreorder: true,
                            enabletooltips: true,
                                // appends buttons to the status bar.
                                var container = $("<div style='overflow: hidden; position: relative; margin: 2px;'></div>");
                                var addButton = $("<div style='float: left; margin-left: 5px;'><img style='position: relative; margin-top: 2px;' /><span style='margin-left: 4px; position: relative; top: -3px;'>Add row</span></div>");
                                var deleteButton = $("<div style='float: left; margin-left: 5px;'><img style='position: relative; margin-top: 2px;' /><span style='margin-left: 4px; position: relative; top: -3px;'>Delete row</span></div>");
                                var saveButton = $("<div style='float: left; margin-left: 5px;'><img style='position: relative; margin-top: 2px;' /><span style='margin-left: 4px; position: relative; top: -3px;'>Save row</span></div>");
                                var emailButton = $("<div style='float: left; margin-left: 5px;'><img style='position: relative; margin-top: 2px;' /><span style='margin-left: 4px; position: relative; top: -3px;'>eMail carrier</span></div>");
                                var prnButton = $("<div style='float: left; margin-left: 5px;'><img style='position: relative; margin-top: 2px;' /><span style='margin-left: 4px; position: relative; top: -3px;'>Print</span></div>");
                                container.append(addButton);
                                container.append(saveButton);
                                container.append(deleteButton);
                                container.append(emailButton);
                                container.append(prnButton);
                                statusbar.append(container);
                                addButton.jqxButton({ theme: 'ui-sunny', width: 60, height: 15 });
                                deleteButton.jqxButton({ theme: 'ui-sunny', width: 65, height: 15 });
                                saveButton.jqxButton({ theme: 'ui-sunny', width: 65, height: 15 });
                                emailButton.jqxButton({ theme: 'ui-sunny', width: 80, height: 15 });
                                prnButton.jqxButton({ theme: 'ui-sunny', width: 65, height: 15 });
                                // add new row.
                                addButton.click(function (event) {
                                    var datainformation = grid.jqxGrid('getdatainformation');
                                    var rowscount = datainformation.rowscount;
                                    if (rowscount == null || rowscount == undefined)
                                        var rowscount = 0;
                                    var editrow = rowscount + 1;
                                    var datarow = generaterow(rowscount + 1);
                                    datarow.ShipId = (rowscount + 1);
                                    datarow.OrderId = id;
                                    grid.jqxGrid('addrow', (rowscount + 1), datarow, 'top');
                                    mode = 1;
                                // delete selected row.
                                deleteButton.click(function (event) {
                                    var rowscount = grid.jqxGrid('getdatainformation').rowscount;
                                    var selectedrowindex = grid.jqxGrid('getselectedrowindex');
                                        var id = grid.jqxGrid('getrowid', selectedrowindex);
                                        var dataRecord = grid.jqxGrid('getrowdata', selectedrowindex);
                                        grid.jqxGrid('deleterow', id);
                                        mode = 0;
                                    var args = event.args;
                                    var rowindex = args.rowindex;
                                    grid.jqxGrid('deleterow', rowindex);
                                prnButton.click(function (event) { DoPrintableSections(100, 200) })
                                // save selected row.
                                saveButton.click(function (event) {
                                    mode = 0;
                                    if (selectedrowindex >= 0 && selectedrowindex <= rowscount) {
                                        var bal1 = dataRecord.ShipQty;
                                        var bal2 = dataRecord.PendingShipQty;
                                        var val3 = dataRecord.OrderId;
                                        psquantity = psquantity - bal1;
                                        $('#grid').jqxGrid('setcellvalue', Rcell.row, "PendingShipQty", psquantity);
                                        if (shipssbyid.length > 0)
                                            for (var i = 0; i < shipssbyid.length; i++) {
                                                if (dataRecord.PendingShipQty == 0 && shipssbyid[i]["OrderId"] == val3) {
                                                    orderstatus = "Payment Pending ";
                                                    break;
                                        else
                                            if (dataRecord.PendingShipQty == 0)
                                                orderstatus = "Payment Pending";
                                        if (dataRecord.ProductCode == null || dataRecord.ProductDesc == null || dataRecord.ShipQty == 0 || dataRecord.OrderQty == 0) {
                                            alert("Incomplete data!!");
                                        else {
                                            var jsonString11 = new Array();
                                            var jsonString2 = new Array();
                                            var jsonString3 = new Array();
                                            var dateString = dataRecord.ShipDate;
                                            var month = dateString.getMonth() + 1;
                                            var day = dateString.getDate();
                                            var year = dateString.getFullYear();
                                            key2 = month + "/" + day + "/" + year;
                                            dataRecord.ShipDate = key2;
                                                jsonString11 = JSON.stringify(dataRecord);
                                                jsonString2 = jsonString11.replace(/{/, '');
                                                jsonString11 = jsonString2.replace(/}/, '');
                                                jsonString2 = jsonString11.replace(/"/g, '');
                                                jsonString11 = jsonString2.replace(/\w+:/g, '^');
                                                jsonString2 = jsonString11.replace(/\,d+,/g, '');
                                            var jsonOfLog;
                                            jsonOfLog = jsonString2;
                                                $.ajax
                                                      cache: false,
                                                      dataType: 'json',
                                                      url: '/Ship/Create?var1=' + orderstatus,
                                                      type: "POST",
                                                      data: { jsonOfLog: jsonOfLog },
                                                      traditional: true,
                                                          alert("returned from server " + data);
                                                          alert(errorThrown);
                              { text: 'OrderId', datafield: 'OrderId', width: 200, hidden: true},
                              { text: 'OrderDtId', datafield: 'OrderDetailId', width: 200, hidden: true },
                              { text: 'Description', datafield: 'ProductDesc',   width: 200 },
                              { text: 'Code', datafield: 'ProductCode', editable: false, width: 100 },
                                  text: 'Ship Date', datafield: 'ShipDate', width: 100, columntype: 'datetimeinput', cellsformat: "MM/dd/yyyy",
                                  align: 'center', cellsalign: 'center', cellbeginedit: rowEdit,
                                  validation: function (cell, value) {
                                      if (value < new Date()) {
                                          return { result: false, message: " error !! Ship date should be >= today!!" };
                                      return true;
                              { text: 'Ord Qty', datafield: 'OrderQty', editable: false, width: 70 },
                              { text: 'Ship Bal', datafield: 'PendingShipQty', editable: false, width: 70},
                                  text: 'Stock Qty', datafield: 'StockQty', editable: false, width: 70, cellbeginedit: rowEdit
                                  text: 'Ship Qty', datafield: 'ShipQty', width: 70,
                                      if (value <= 0) {
                                          return { result: false, message: " error !! Ship Quantity should be >= 1 " };
                                      if ((value > psquantity)) {
                                          return { result: false, message: " error !! Ship Quantity should be <= pending ship Quantity !!! " };
                                      else if (value <= psquantity) {
                                          $('#grid').jqxGrid('setcellvalue', cell.row, "PendingShipQty", (psquantity - value));
                                          return true;
                              { text: 'Shipped?', datafield: 'ShipStatus', editable: true, width: 80, columntype: 'checkbox'},
                              { text: 'Notes', datafield: 'Notes', editable: true, width: 330 }
                    // nested grid rowclick binding
                    $("#grid").on("rowclick", function (event) {
                        referencerow = rowindex;
                function DoPrintableSections(wdth, hght) {
                    // CreateVirtualCarrier("ContentCarrier");
                    var cc = document.getElementById("ContentCarrier");
                    var e = document.getElementsByTagName("div");
                    var cc = document.getElementById("cc");
                    cc.innerHTML = "Cancer curing drugs";
                    var content = "Packing slip";
                    content += "<br/>" + cc.innerHTML;
                    OpenPreviewPage(content, 500, 200);
                    cc.innerHTML = "";
                function CreateVirtualCarrier(carriername) {
                    var vc = document.createElement('<div id="' + carriername + '" style="+ "width:600; height:200;"></div>');
                    document.body.appendChild(vc);
                function OpenPreviewPage(content, wdth, hght) {
                    var imgsdir;
                    PreviewPage = window.open('', 'PreviewPage', 'width=' + wdth + ',height=' + hght + ',menubar=0,toolbar=1,status=0,scrollbars=1,resizable=1');
                    PreviewPage.document.open("text/html", "replace");
                    PreviewPage.document.writeln('<html><head><title>PrintPreview</title>'
                    + '</head><body align="left"  onLoad="self.focus()">'
                    + content
                    + '</body>' + '<button onclick="javascript:window.print()">Print</button>' + '</html>');
                    PreviewPage.document.close();
                var rowEdit = function (row, column) {
                    if (row != 0 && column != "ShipStatus")
                        return false;
                    else if (row == 0 && column != "ShipStatus" && mode == 0) {
                        return false;
                    else if (row == 0 && mode == 1)
                        return true;
                var renderer = function (row, column, value) {
                    return '<span style="margin-left: 4px; margin-top: 5px; float: left;">' + value + '</span>';
                var source3 =
                    datafields:
                        { name: 'CustomerId' },
                        { name: 'CustomerName' }
                    url: '/Ship/GetCustomer',
                    async: false
                var dropDownLS = new $.jqx.dataAdapter(source3, {
                            { name: 'CustomerName', value: 'CustomerId', values: { source: dropDownLS.records, value: 'CustomerId', name: 'CustomerName' } },
                            { name: 'OrderDate', type: 'date', format: 'MM/dd/yyyy' },
                            { name: 'OrderAmount' },
                            { name: 'OrderStatus' },
                        async: false,
                        url: url
                var orderAdapter = new $.jqx.dataAdapter(source);
                // create jqxgrid
                var invoiceNumRenderer = function (row, columnfield, value, defaulthtml, columnproperties) {
                    var theStatus = $("#orderheaderGrid").jqxGrid('getrowdata', row).OrderStatus;
                    if (theStatus == "Shipment Pending") {
                        return '<span style="margin: 4px;float: ' + columnproperties.cellsalign + ';color: #ff0000;font-weight: bold">' + value + '</span>';
                    } else if (theStatus == "Part Shipment") {
                        return '<span style="margin: 4px;float: ' + columnproperties.cellsalign + ';color: #006638;font-weight: bold">' + value + '</span>';
                    } else if (theStatus == "New Order") {
                        return '<span style="margin: 4px;float: ' + columnproperties.cellsalign + ';color: #9B30FF;font-weight: bold">' + value + '</span>';
                var OrderNumRenderer = function (row, columnfield, value, defaulthtml, columnproperties) {
                    var theStatus = $("#orderheaderGrid").jqxGrid('getrowdata', row).OrderAmount;
                    if (theStatus > 100000) {
                    } else if (theStatus <= 10000) {
                    } else if (theStatus > 10000 && theStatus <= 100000) {
                var AgeNumRenderer = function (row, columnfield, value, defaulthtml, columnproperties) {
                    var one_day = 1000 * 60 * 60 * 24;
                    var dt = $("#orderheaderGrid").jqxGrid('getrowdata', row).OrderDate;
                    var date1 = new Date(dt); //Month is 0-11 in JavaScript
                    var date2 = new Date();
                    var date1_ms = date1.getTime();
                    var date2_ms = date2.getTime();
                    var difference_ms = date2_ms - date1_ms;
                    theStatus = Math.round(difference_ms / one_day);
                    if (theStatus > 2) {
                    } else if (theStatus <= 1) {
                    } else if (theStatus == 2) {
                    width: 945,
                    height: 370,
                    source: orderAdapter,
                    theme: 'ui-sunny',
                    rowdetails: true,
                    rowsheight: 25,
                    groupable: true,
                    rowdetailstemplate: { rowdetails: "<div id='grid' style='margin: 3px;'></div>", rowdetailsheight: 150, rowdetailshidden: true },
                    ready: function () {
                        $("#orderheaderGrid").jqxGrid('showrowdetails', -1);
                    columns:
                          { text: 'OrderId', datafield: 'OrderId', width: 100, editable: false, cellsrenderer: renderer },
                              text: 'Customer', datafield: 'CustomerId', displayfield: 'CustomerName', columntype: 'dropdownlist', editable: false, width: 380, cellsrenderer: renderer
                          { text: 'Order Date', datafield: 'OrderDate', formatString: 'MM/dd/yyyy', editable: false, theme: 'ui-sunny', width: 180, cellsrenderer: AgeNumRenderer },
                          { text: 'Order Amount', datafield: 'OrderAmount', width: 100, editable: false, cellsrenderer: OrderNumRenderer },
                          { text: 'Status', datafield: 'OrderStatus', width: 130, cellsalign: 'right', cellsrenderer: invoiceNumRenderer },
                var generaterow1 = function (id) {
                    var row = {};
                    row["OrderDetailId"] = id;
                    row["ProductId"];
                    row["CategoryId"] = gid1;
                    row["BrandId"] = gid2;
                    row["OrderId"];
                    row["ProductCode"] = " ";
                    row["ProductDesc"] = " ";
                    row["StockQty"];
                    row["Quantity"];
                    row["SellPrice"];
                    row["ItemValue"];
                    row["PendingShipQty"] = 0;
                    row["Cancelled"] = 0;
                    return row;
                $("#orderheaderGrid").on('rowselect', function (event) {
                    gid1 = event.args.row.OrderId;
                    orefid = gid1;
                    var source1 =
                       //  datafields: dataFields,
                       datafields:
                          { name: 'ProductId' },
                          { name: 'CategoryId' },
                          { name: 'BrandId' },
                          { name: 'ProductCode', type: 'string' },
                          { name: 'ProductDesc', type: 'string' },
                          { name: 'StockQty' },
                          { name: 'Quantity' },
                          { name: 'SellPrice' },
                          { name: 'ItemValue' },
                       url: '/AmendOrder/GetOrderDetail?var1=' + gid1
                    var dataAdapter = new $.jqx.dataAdapter(source1);  //   on 11 feb 2014
                    $("#orderdetailGrid").jqxGrid(
                         width: 945,
                         height: 400,
                         theme: 'ui-sunny',
                         groupable: true,
                         keyboardnavigation: false,
                         rendered: function (type) {
                             // select all grid cells.
                             var gridCells = $('#orderdetailGrid').find('.jqx-grid-cell');
                             // initialize the jqxDragDrop plug-in. Set its drop target to the second Grid.
                             gridCells.jqxDragDrop({
                                 appendTo: 'body', theme: "ui-sunny", dragZIndex: 99999,
                                 dropAction: 'none',
                                 initFeedback: function (feedback) {
                                     feedback.height(25);
                                 onTargetDrop: function (a, b, c, d, e) {
                                 dropTarget: $('#grid0'), revert: true
                             gridCells.off('dragStart');
                             gridCells.off('dragEnd');
                             gridCells.off('dropTargetEnter');
                             gridCells.off('dropTargetLeave');
                             // disable revert when the dragged cell is over the second Grid.
                             gridCells.on('dropTargetEnter', function () {
                                 gridCells.jqxDragDrop({ revert: false });
                             // enable revert when the dragged cell is outside the second Grid.
                             gridCells.on('dropTargetLeave', function () {
                                 gridCells.jqxDragDrop({ revert: true });
                             // initialize the dragged object.
                             gridCells.on('dragStart', function (event) {
                                 var value = $(this).text();
                                 var position = $.jqx.position(event.args);
                                 var cell = $("#orderdetailGrid").jqxGrid('getcellatposition', position.left, position.top);  // original line
                                 refdata = 0; // ADDED 30 jan 2014
                                 refdata = $('#orderdetailGrid').jqxGrid('getcellvalue', cell.row, "OrderDetailId");  // ADDED 30 jan 2014
                                 $(this).jqxDragDrop('data', {
                                     value: value
                             // set the new cell value when the dragged cell is dropped over the second Grid.
                             gridCells.on('dragEnd', function (event) {
                                 oldvalue = 0;
                                 var idx = 0;
                                 var valueDesc = $(this).text();
                                 var cell;
                                 Rcell = cell;
                                 if (valueDesc != null) {
                                //     idx = getItemIndex(valueDesc + refdata);  // ADDED refdata on 30 Jan 2014
                                     idx = 1;
                                     if (idx != -1) {
                                         if (cell != null) {
                                             var vd2 = $('#grid').jqxGrid('getcellvalue', cell.row, " ProductDesc");
                                             var aq2 = $('#grid').jqxGrid('getcellvalue', cell.row, "OrderQty");
                                             var pq2 = $('#grid').jqxGrid('getcellvalue', cell.row, "PendingShipQty");
                                             var sid = $('#grid').jqxGrid('getcellvalue', cell.row, "ShipId");
                                             var oid = $('#grid').jqxGrid('getcellvalue', cell.row, "OrderId");
                                             if ((vd2 == null) && (aq2 != 0 || pq2 != 0) && (orefid == oid)) {  // changed both from /
                                                 //addded oid==gid
                                                 cartItems.push(valueDesc);
                                                 $("#grid").jqxGrid('setcellvalue', cell.row, "ProductDesc", valueDesc);
                                                 $("#grid").jqxGrid('setcellvalue', cell.row, "ProductCode", pc);
                                                 $("#grid").jqxGrid('setcellvalue', cell.row, "OrderQty", stockqty);
                                                 $("#grid").jqxGrid('setcellvalue', cell.row, "PendingShipQty", psquantity);
                                                 $("#grid").jqxGrid('setcellvalue', cell.row, "OrderDetailId", odid);
                                                 $("#grid").jqxGrid('setcellvalue', cell.row, "StockQty", invqty);
                                                 cartItems.push(valueDesc + refdata);// ADDED refdata on 30 Jan 2014
                                                 var sri = 0;
                                                 valueDesc = " "; // added today
                                             else {
                                                 alert("Drop properly on a empty row / add new row / check OrderId, Drag and drop item on it !!!");
                                     else {
                                         var sq2 = $('#grid').jqxGrid('getcellvalue', cell.row, "OrderQty");
                                         oldvalue = sq2;
                                         alert("Item already exists !!!  ");
                             function getItemIndex(value) {
                                 for (var i = 0; i < cartItems.length; i += 1) {
                                     if (cartItems[i] == value) {
                                         return -1;
                                 return i;
                             $("#orderdetailGrid").bind('cellclick', function (event) {
                                 alert("cell clicked order detail ");
                                 var index = event.args.rowindex;
                                 var dataRecord = $("#orderdetailGrid").jqxGrid('getrowdata', index);
                                 stockqty = dataRecord.Quantity;
                                 sellprice = dataRecord.SellPrice;
                                 pc = dataRecord.ProductCode;
                                 psquantity = dataRecord.PendingShipQty;
                                 pid = dataRecord.ProductId;
                                 gid1 = dataRecord.CategoryId;
                                 gid2 = dataRecord.BrandId;
                                 oid = dataRecord.OrderId;
                                 odid = dataRecord.OrderDetailId;
                                 invqty = dataRecord.StockQty;
                         theme: 'ui-sunny',
                         selectionmode: 'singlerow',
                         columns:
                            { text: 'ProductId', datafield: 'ProductId', hidden: true, width: 100 },
                            { text: 'CategoryId', datafield: 'CategoryId', hidden: true, width: 100 },
                            { text: 'BrandId', datafield: 'BrandId', hidden: true, width: 100 },
                            { text: 'OrderId', datafield: 'OrderId', width: 50 },
                            { text: 'O-DetlId', datafield: 'OrderDetailId', width: 60 },
                            { text: 'Product Code', datafield: 'ProductCode', width: 115 },
                            { text: 'Description', datafield: 'ProductDesc', width: 300 },
                            { text: 'Model', datafield: 'Model', width: 180 },
                            { text: 'Stock Qty', datafield: 'StockQty', width: 80 },
                            { text: 'Qty', datafield: 'Quantity', width: 80 },
                            { text: 'Price', datafield: 'SellPrice', width: 80 },
                            { text: 'Pending Ship Qty', datafield: 'PendingShipQty', width: 80 },
                var menuNo = 12;
                var lenth = 14;
                for (var j = 1; j <= lenth; j++) {
                    if (j == menuNo) {
                        $(("#") + (j)).css("background-color", "maroon");
                    else
                        $(("#") + (j)).css("background-color", "null");
                wireUpEvents();
            <div id="orderheaderGrid"></div>
            <div id="grid"></div>
            <div id="orderdetailGrid" style="margin-left: 1px; margin-top: 7px;"></div>
            <div id="cc" style="margin-left: 1px; margin-top: 7px;"></div>
    Keshavan
    Jqwidgets version 3.8
    Keshavan
    Hi Keshavan,
    We cannot test your example, because we do not have access to your grid data. Your code is also too extensive for us to look into thoroughly. If you can reproduce the behaviour on a smaller scale or if you wish us to examine only a part of the code, we may be able to assist you. Share if any errors are thrown in your browser’s console, too.
    Keshavan
    Hi Dimitar,
    I have removed code not relevant and here is the shortened code.
    Keshavan
        </title>
            var refGrid;
                var gid3 = 1;
                var data = {};
                var cartItems = [];
                var arowid = [];
                var grid;
                    var row = {};
                    row["CustomerId"];
                    row["OrderDate"];
                    row["OrderAmount"];
                    row["OrderStatus"];
                    return row;
                var shipSource =
    					{ name: 'ShipId' },
                        { name: 'Notes' },
                    url: shipurl,
                    async: false
                        if (result)
                        var row = {};
                        row["ShipId"];
                        row["Notes"] = " ";
                        row["ProductCode"];
                        row["ProductDesc"];
                        row["OrderQty"];
                        row["ShipQty"] = 0;
                        row["ShipDate"];
                        row["Cancelled"];
                        return row;
                    var shipsource = {
                            { name: 'ShipId' },
                            { name: 'Notes' },
                    if (grid != null) {
                        grid.jqxGrid({
                            width: 900,
                                // add new row.
                                        var rowscount = 0;
                                    mode = 1;
                                        mode = 0;
                                    mode = 0;
                                                    break;
                                        else
                                        else {
                                            var jsonOfLog;
                                                $.ajax
                                                      cache: false,
                                                      dataType: 'json',
                                                      type: "POST",
                                                      traditional: true,
                                                          alert(errorThrown);
                                      return true;
                                      if (value <= 0) {
                                          return true;
                var source3 =
                    datafields:
                    async: false
                        async: false,
                        url: url
                    width: 945,
                    height: 370,
                    theme: 'ui-sunny',
                    rowdetails: true,
                    rowsheight: 25,
                    groupable: true,
                    columns:
                          { text: 'OrderId', datafield: 'OrderId', width: 100, editable: false },
                          { text: 'Order Date', datafield: 'OrderDate', formatString: 'MM/dd/yyyy', editable: false, theme: 'ui-sunny', width: 180 },
                          { text: 'Order Amount', datafield: 'OrderAmount', width: 100, editable: false },
                          { text: 'Status', datafield: 'OrderStatus', width: 130, cellsalign: 'right'},
                    var row = {};
                    row["ProductId"];
                    row["OrderId"];
                    row["StockQty"];
                    row["Quantity"];
                    row["SellPrice"];
                    row["ItemValue"];
                    return row;
                    orefid = gid1;
                    var source1 =
                       datafields:
                         width: 945,
                         height: 400,
                         theme: 'ui-sunny',
                         groupable: true,
                                 dropAction: 'none',
                                     value: value
                                 oldvalue = 0;
                                 var idx = 0;
                                 var cell;
                                 Rcell = cell;
                                     idx = 1;
                                     if (idx != -1) {
                                         if (cell != null) {
                                                 //addded oid==gid
                                                 var sri = 0;
                                             else {
                                     else {
                                         oldvalue = sq2;
                                         return -1;
                                 return i;
                         theme: 'ui-sunny',
                         columns:
    Keshavan
    Nested Grid – DRag/Drop implementation details.
    Outer grid name – orderheaderGrid
    Inner grid name – grid
    Name of the Other Grid (seperate from Nested Grid) – orderdetailGrid.
    Nested Grid is properly implemented and is working OK. orderdetail grid is seperately working OK.
    Issue only in Drag-Drop.
    I have Implemented Drag-Drop from the above mentioned Other Grid(orderdetailGrid) in to inner grid (name of Grid – grid) of nested Grid.
    With below drag-drop implementation , i am referenncing “cell” in dragend as in the below line,
    cell = $(“#grid”).jqxGrid(‘getcellatposition’, position.left, position.top);
    Browser Console displayed – Invalid selctor – check Id or Css.
    when i checked the Id programatically, in Nested Grid, The Inner grid (name of Grid : grid) the Id was grid0, grid1, grid2, …. gridn depending
    on the row of the outer grid of nested grid.
    so i used, var grid = “grid” + referencerow; in dragend code (pasted below).
    $(“#grid”).on(“rowclick”, function (event) {
    Now , browser console shows NO error but Drop doesn’t happen, the target row remains blank.
    $(“#orderdetailGrid”).jqxGrid(
    width: 945,
    height: 400,
    theme: ‘ui-sunny’,
    groupable: true,
    var gridCells = $(‘#orderdetailGrid’).find(‘.jqx-grid-cell’);
    appendTo: ‘body’, theme: “ui-sunny”, dragZIndex: 99999,
    dropAction: ‘none’,
    dropTarget: $(‘#grid0’), revert: true
    gridCells.off(‘dragStart’);
    gridCells.off(‘dragEnd’);
    gridCells.off(‘dropTargetEnter’);
    gridCells.off(‘dropTargetLeave’);
    gridCells.on(‘dropTargetEnter’, function () {
    gridCells.on(‘dropTargetLeave’, function () {
    gridCells.on(‘dragStart’, function (event) {
    var cell = $(“#orderdetailGrid”).jqxGrid(‘getcellatposition’, position.left, position.top); // original line
    refdata = $(‘#orderdetailGrid’).jqxGrid(‘getcellvalue’, cell.row, “OrderDetailId”); // ADDED 30 jan 2014
    $(this).jqxDragDrop(‘data’, {
    value: value
    gridCells.on(‘dragEnd’, function (event) {
    oldvalue = 0;
    var idx = 0;
    var cell;
    Rcell = cell;
    idx = 1;
    if (idx != -1) {
    if (cell != null) {
    var vd2 = $(‘#grid’).jqxGrid(‘getcellvalue’, cell.row, ” ProductDesc”);
    var aq2 = $(‘#grid’).jqxGrid(‘getcellvalue’, cell.row, “OrderQty”);
    var pq2 = $(‘#grid’).jqxGrid(‘getcellvalue’, cell.row, “PendingShipQty”);
    var sid = $(‘#grid’).jqxGrid(‘getcellvalue’, cell.row, “ShipId”);
    var oid = $(‘#grid’).jqxGrid(‘getcellvalue’, cell.row, “OrderId”);
    //addded oid==gid
    $(“#grid”).jqxGrid(‘setcellvalue’, cell.row, “ProductDesc”, valueDesc);
    $(“#grid”).jqxGrid(‘setcellvalue’, cell.row, “ProductCode”, pc);
    $(“#grid”).jqxGrid(‘setcellvalue’, cell.row, “OrderQty”, stockqty);
    $(“#grid”).jqxGrid(‘setcellvalue’, cell.row, “PendingShipQty”, psquantity);
    $(“#grid”).jqxGrid(‘setcellvalue’, cell.row, “OrderDetailId”, odid);
    $(“#grid”).jqxGrid(‘setcellvalue’, cell.row, “StockQty”, invqty);
    var sri = 0;
    valueDesc = ” “; // added today
    else {
    alert(“Drop properly on a empty row / add new row / check OrderId, Drag and drop item on it !!!”);
    else {
    var sq2 = $(‘#grid’).jqxGrid(‘getcellvalue’, cell.row, “OrderQty”);
    oldvalue = sq2;
    alert(“Item already exists !!! “);
    My HTML is as below,
    <body class=’default’>
    <div id=’jqxWidget’ style=”font-size: 13px; font-family: Verdana; float: left;”>
    <div id=”orderheaderGrid”></div>
    <div id=”grid”></div>
    <div id=”orderdetailGrid” style=”margin-left: 1px; margin-top: 7px;”></div>
    Keshavan
    Here is the Shortened, formatted code.
    Keshavan
    referencerow is a global variable.
     width: 945,
     height: 400,
     theme: ‘ui-sunny’,
     groupable: true,
     dropAction: ‘none’,
     dropTarget: $(‘#grid0′), revert: true
    value: value
     oldvalue = 0;
     var idx = 0;
     var cell;
     Rcell = cell;
     idx = 1;
     if (idx != -1) {
     if (cell != null) {
     //addded oid==gid
     var sri = 0;
     else {
    else {
    oldvalue = sq2;
    Hi Keshavan,
    You have defined a variable grid:
    yet you never use it anywhere else in your code, but continue to use the selection $('#grid'). We suggest to modify the dragEnd event handler as follows:
        oldvalue = 0;
        var idx = 0;
        var cell;
        var grid = $("#grid" + referencerow);
        cell = grid.jqxGrid('getcellatposition', position.left, position.top);
        Rcell = cell;
            idx = 1;
            if (idx != -1) {
                if (cell != null) {
                    var vd2 = grid.jqxGrid('getcellvalue', cell.row, " ProductDesc");
                    var aq2 = grid.jqxGrid('getcellvalue', cell.row, "OrderQty");
                    var pq2 = grid.jqxGrid('getcellvalue', cell.row, "PendingShipQty");
                    var sid = grid.jqxGrid('getcellvalue', cell.row, "ShipId");
                    var oid = grid.jqxGrid('getcellvalue', cell.row, "OrderId");
                        //addded oid==gid
                        grid.jqxGrid('setcellvalue', cell.row, "ProductDesc", valueDesc);
                        grid.jqxGrid('setcellvalue', cell.row, "ProductCode", pc);
                        grid.jqxGrid('setcellvalue', cell.row, "OrderQty", stockqty);
                        grid.jqxGrid('setcellvalue', cell.row, "PendingShipQty", psquantity);
                        grid.jqxGrid('setcellvalue', cell.row, "OrderDetailId", odid);
                        grid.jqxGrid('setcellvalue', cell.row, "StockQty", invqty);
                        cartItems.push(valueDesc + refdata); // ADDED refdata on 30 Jan 2014
                        var sri = 0;
                    } else {
            } else {
                var sq2 = grid.jqxGrid('getcellvalue', cell.row, "OrderQty");
                oldvalue = sq2;
    Keshavan
    I have updated with minimum code and pasted in the post, Please let me know whether implementing Drag-Drop on nested grid is Possible / Not Possible
    so that I can alter my solution to use different layout etc.
    Keshavan
    Keshavan
    Hi Dimitar,
    Thanks a million !!. With your help I am able to complete it.
    Under pressure I didn’t see your solution earlier.
    Keshavan
