jQuery UI Widgets Forums Navigation Tabs Delete, Add, Then Select does not work
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 7 years, 10 months ago.
  • klh717
    I have a case where I’m dynamically loading tabs on a page. The issue I have is trying to clear the previous tabs to recreate the new ones. When I do this, the select method does not work. Please see the following Fiddle, click the button and you can see that the last tab is selected, not the first one. Is there a work around? I originally tried to destroy the tab and make a new one but that doesn’t seem to work the same way as other objects.
    This appears to only be a problem if an item is deleted prior to the add.
    http://jsfiddle.net/zyp0ysg1/1/
    Thank you,
    Kris
    Hello Kris,
    The mentioned scenario happens very fast and I would like to suggest you using setTimeout to select the first tab.
