jQuery UI Widgets Forums Grid Decimal digits does not work
This topic contains 1 reply, has 2 voices, and was last updated by  Nadezhda 10 years, 5 months ago.
  • Decimal digits does not work #61031
    mustafa
    hello I’ve added a number of grid,but Decimal digits does not work
      { text: 'Expense Sum', datafield: 'ExpenseSum', inputMode: 'simple', align: 'right', cellsalign: 'right', width: 200,  decimal: 2,spinButtons: true ,columntype: "numberinput" },
    Decimal digits does not work #61040
    Nadezhda
    Hello mustafa,
    You are using properties of jqxNumberInput in jqxGrid and this is the reason that digits doesn’t work. Please, find below an example which uses “createeditor” function for adding parameters to the editor.
      { text: 'Expense Sum', datafield: 'ExpenseSum',  align: 'right', cellsalign: 'right', width: 200,  columntype: "numberinput"
     createeditor: function (row, cellvalue, editor, celltext, cellwidth, cellheight) {
        editor.jqxNumberInput({  decimal: 100, spinButtons: true, inputMode: 'simple', decimalDigits: 2, decimalSeparator: "," });
    Nadezhda
