jQuery UI Widgets › Forums › Editors › DateTimeInput › Datepicker in the same page with grid not working
Tagged: datepicker, datetimeinput, grid, jqxdatetimeinput, jqxgrid, JSP
This topic contains 3 replies, has 2 voices, and was last updated by nitin7988 10 years, 6 months ago.
I have jsp page in that when i used datepicker it works fine but when i added an jqxgrid in the same page the datepicker dosenot works.
Can someone help me in this.Hello nitin7988,
This information is insufficient for us to determine the source of the issue. Please, provide a sample which illustrates your issue.
NadezhdajQWidgets team
http://www.jqwidgets.com/The grid is saved in a seperate page
<script type=”text/javascript” src=”../../jqwidgets/jqxgrid.columnsresize.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxgrid.sort.js”></script><script type=”text/javascript” src=”../../jqwidgets/jqxcheckbox.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxgrid.edit.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxgrid.selection.js”></script><script type=”text/javascript” src=”../../jqwidgets/jqxgrid.pager.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxgrid.filter.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/globalization/globalize.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxpanel.js”></script><script type=”text/javascript”>
var data= ‘<%=com.controlcentre.masters.vehiclemaster.brand.ClsBrandAction.searchDetails() %>’;
$(document).ready(function () {var num = 0;
{name : ‘DOC_NO’ , type: ‘int’ },
{name : ‘BRAND_NAME’, type: ‘String’ },
{name : ‘DATE’, type: ‘String’ }],
localdata: data,pager: function (pagenum, pagesize, oldpagenum) {
};var dataAdapter = new $.jqx.dataAdapter(source,
alert(error);
$(“#jqxBrandSearch”).jqxGrid(
width: ‘75%’,
height: 315,
altRows: true,
selectionmode: ‘singlerow’,
pagermode: ‘default’,//Add row method
{ text: ‘DOC_NO’, datafield: ‘DOC_NO’, width: ‘10%’ },
{ text: ‘BRAND_NAME’, datafield: ‘BRAND_NAME’, width: ‘50%’ },
{ text: ‘DATE’, datafield: ‘DATE’, width: ‘40%’ }
$(‘#jqxBrandSearch’).on(‘rowselect’, function (event) {
var rowindex1=event.args.rowindex;
document.getElementById(“docno”).value= $(‘#jqxBrandSearch’).jqxGrid(‘getcellvalue’, rowindex1, “DOC_NO”);
document.getElementById(“brand”).value = $(“#jqxBrandSearch”).jqxGrid(‘getcellvalue’, rowindex1, “BRAND_NAME”);
document.getElementById(“date_brand”).value = $(“#jqxBrandSearch”).jqxGrid(‘getcellvalue’, rowindex1, “DATE”);
document.close();
<div id=”jqxBrandSearch”></div>and this grid page is included in a main page where date picker is also specified in this way
<link rel=”stylesheet” href=”../../jqwidgets/styles/jqx.base.css” type=”text/css”/>
<script type=”text/javascript” src=”../../jqwidgets/jqxdatetimeinput.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxcalendar.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxtooltip.js”></script>
$(“#jqxDateTimeInput”).jqxDateTimeInput({ min: new Date(2010, 0, 1), max: new Date(2014, 11, 31), width: ‘125px’, height: ’15px’});
<div id=’jqxDateTimeInput’></div>the date picker works when its used without grid.
but when grid page is included the date picker dosenot works.solved the issue same js files where included 2 twice.
Once in the main page and next time in the grid page. -
