jQuery UI Widgets Forums DataTable DataTable not respecting array order
This topic contains 1 reply, has 2 voices, and was last updated by  Todor 6 years ago.
  • gawyndragonspawn
    Greetings,
    I’m attempting to use the Datatable to create something similar to rows rendering example.
    I’m successfully loading my data from my API as JSON, but this is where I run into an issue. All of my sorting, filtering, etc is done server side, and returns the JSON object in the order I desire it to output. This works perfectly, as long as I don’t group the items in the Datatable.
    An example:
    I have multiple product categories, eg. Cat1, Cat2, Cat3. Each of these categories has 1 or more sub categories, eg. Cat1Sub1, Cat1Sub2, etc. When I initialize the table, I use groups: [“BrandTitle”, “BrandName”] to combine the appropriate groups/subgroups. The JSON object would like this:
    Available: “Available”
    BrandName: “Cat1SubCat1”
    BrandTitle: “Cat1”
    Description: “Some thing”
    DescriptionFull: “Some new thing from us!”
    ItemNumber: “1234”
    MarketingComments: null
    BrandName: “Cat1SubCat2”
    BrandTitle: “Cat1”
    ItemNumber: “4321”
    BrandName: “ACatSubCat1”
    BrandTitle: “ACat”
    ItemNumber: “5678”
    If groups are not set, Cat1 and its subcategories will appear first, like I want them to. If groups are set as I mentioned, ACat will appear first. How can I disable this automatic sorting when grouping?
    Dan
    DataTable not respecting array order #104768
    Todor
    Hello gawyndragonspawn,
    Unfortunately you cannot disable it. The data should be sorted in order for groups to work.
    Todor
    https://www.jqwidgets.com
