jQuery UI Widgets Forums DataTable Data string going to integer
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 9 years, 4 months ago.
  • Data string going to integer #79366
    No One
    First data in my table became integer ( should be string ) eg. “0000001” = “1”
    I created this example to show you my problem. I’m using jQWidgets v3.7.0 (2015-Feb)
    <html>
      <link rel = "stylesheet" href = "http://jqwidgets.com/public/jqwidgets/styles/jqx.base.css" type = "text/css" />
      <script type = "text/javascript" src = "http://jqwidgets.com/public/jqwidgets/scripts/jquery-1.11.1.min.js"> </script>
      <script type = "text/javascript" src = "http://jqwidgets.com/public/jqwidgets/jqxcore.js"> </script>
      <script type = "text/javascript" src = "http://jqwidgets.com/public/jqwidgets/jqxbuttons.js"> </script>
      <script type = "text/javascript" src = "http://jqwidgets.com/public/jqwidgets/jqxscrollbar.js"> </script>
      <script type = "text/javascript" src = "http://jqwidgets.com/public/jqwidgets/jqxdata.js"> </script>
      <script type = "text/javascript" src = "http://jqwidgets.com/public/jqwidgets/jqxdatatable.js"> </script>
      <script type = "text/javascript">
       var data = [];
       for (var counter = 0; counter < 100; counter ++)
        data[counter] = {
         id: counter + 1,
         no: "00000000" + (counter + 1)
       $("#table").jqxDataTable({
         { text: "No.", dataField: "no" },
         { text: "Id", dataField: "id" }
        height: 500,
        source: new $.jqx.dataAdapter({
         dataType: "json",
         localData: data
        width: 500
     <body>
      <div id = "table"> </div>
    I tried setting the type but it still change to integer.
    Hoping you could help me.
    Thank you,
    Marco
    Data string going to integer #79381
    Hello No One,
    When use dataAdapter you could set the ‘type’.
    Please take a look Your code below with little changes:
    <html>
        <link rel="stylesheet" href="http://jqwidgets.com/public/jqwidgets/styles/jqx.base.css" type="text/css" />
        <script type="text/javascript" src="http://jqwidgets.com/public/jqwidgets/scripts/jquery-1.11.1.min.js"> </script>
        <script type="text/javascript" src="http://jqwidgets.com/public/jqwidgets/jqxcore.js"> </script>
        <script type="text/javascript" src="http://jqwidgets.com/public/jqwidgets/jqxbuttons.js"> </script>
        <script type="text/javascript" src="http://jqwidgets.com/public/jqwidgets/jqxscrollbar.js"> </script>
        <script type="text/javascript" src="http://jqwidgets.com/public/jqwidgets/jqxdata.js"> </script>
        <script type="text/javascript" src="http://jqwidgets.com/public/jqwidgets/jqxdatatable.js"> </script>
                var data = [];
                for (var counter = 0; counter < 100; counter++) {
                    data[counter] = {
                        id: counter + 1,
                var dataAdapter = new $.jqx.dataAdapter({
                    dataType: "json",
                    dataFields: [
                        { name: 'id', type: 'int' },
                        { name: 'no', type: 'string' },
                    localData: data
                    height: 500,
                    width: 500,
    <body>
        <div id="table"></div>
    We would like to recommend you to use new version of jQWidgets.
