jQuery UI Widgets › Forums › Grid › Data for Invisible Columns When Using Horizontal Bar Is Not Displayed
This topic contains 4 replies, has 2 voices, and was last updated by hus 10 years, 1 month ago.
March 16, 2015 at 4:08 am Data for Invisible Columns When Using Horizontal Bar Is Not Displayed #68570
I am working on jqxgrid (Dynamic Column). Here is part of my code:
$("#jqxgrid").jqxGrid({ width: 566, source: dataAdapter, autoheight: true, columnsresize: true, sortable: false, columns: columns });
They sit in the success handler of the Ajax request. My code will make ajax request every 3 seconds, take the data in json format, and build the jqxgrid. That means it will keep re-generating the grid. However I am having strange situation. In first iteration, the data is displayed as expected. But for the next iteration, the data will be shown on the visible columns only. I have lots of columns, so the horizontal bar is there. The current visible column will show the data but not the invisible one. However if I scroll to the right, on the next iteration the data is displayed and the other invisible column will not have the data. I confirmed that I received all the data. And another interesting part is only the column which has the number is having the problem. The column which has characters is good. I try to change the datafield to string, int, also number but seems no luck as yet. I took days just to figure out this strange behavior. Hopefully somebody could help me. Thank you.
March 16, 2015 at 6:35 am Data for Invisible Columns When Using Horizontal Bar Is Not Displayed #68576Solved by commenting the property
width
. Hope this helps somebody.March 16, 2015 at 6:51 am Data for Invisible Columns When Using Horizontal Bar Is Not Displayed #68578Hello hus,
The width property should not cause any issues. Maybe there is something else in your code that is erroneous. If you wish, post a code snippet that is relevant to the issue and we might be able to help you solve it.
http://www.jqwidgets.com/March 16, 2015 at 7:13 am Data for Invisible Columns When Using Horizontal Bar Is Not Displayed #68580Hi Dimitar,
You are true. Even I don’t believe width causes the problem. I am using this setting
$("#jqxgrid").jqxGrid({ width: 566, height: 250, source: dataAdapter, //autoheight: true, columnsresize: true, sortable: false, columns: columns });
I am beginning to believe that the
autoheight
causes the problem for me. Now everything works just fine. I can now see the data in invisible columns that I need to drag the scroll bar to see it. Any explanation on this? The problem when I usedautoheight
is not only the problem I mentioned earlier, plus when I try to re-size the column, it only re-sized the column virtually. But in fact the real divider (line of column) is still there.Additional question: I put this code in AJAX request under success call back, so that means the grid is re-generated (whole the data and the grid). Is this right way to implement it? Or there is another way? Thank you in advance.
March 16, 2015 at 7:42 am Data for Invisible Columns When Using Horizontal Bar Is Not Displayed #68588Hi Dimitar,
My thought is wrong.
autoheight
is not causing the problem. I still could not able to find the reason of the problem. But I found your solution in another forum and combine it with my code like down herevar parent = $("#jqxgrid").parent(); $("#jqxgrid").jqxGrid('destroy'); $("<div id='jqxgrid'></div>").appendTo(parent); $("#jqxgrid").jqxGrid({ width: 566, height: 220, source: dataAdapter, //autoheight: true, columnsresize: true, sortable: false, columns: columns //shrinkToFit : false });
and so far it works good.
