Hi!
I’m trying to build a custom validation rule to check that the entered serial number is already in use in my server-side database or not. On a blur event I want to start a $.post callback to check the input’s actual value. If it is in the database I want to display an error message to warn the user about the problem. Also when a submit event is fired I want to check this with the ‘validate’ method of jqxValidator if possible.
Thinking about this I can’t use jqxValidator’s custom rule function because if I put a $.post function in it, it will finish before the post returns any value. How can I display this custom message to warn the user and also has the form’s validator to return a false value if the number is in use? Is it possible with jqxValidator?
Thank you for your help,
Imre
