jQuery UI Widgets Forums Grid Custom filter conditions for numeric filter
This topic contains 1 reply, has 2 voices, and was last updated by  Christopher 8 years, 10 months ago.
  • SergioV85
    Hi!
    There is strange behavior for numeric filter element in filter row when using custom filter condition
    Here is sample code
      var loc = {
        filterstringcomparisonoperators: ['Contains', 'Does not contain', 'Empty', 'Not empty'],
        filternumericcomparisonoperators: ['Equal', 'Not equal', 'Null', 'Not null'],
        filterdatecomparisonoperators: ['less than', 'greater than'],
        filterbooleancomparisonoperators: ['Equal', 'Not equal']
      var data = generatedata(500);
      var source = {
        localdata: data,
        datafields: [{
          type: 'string'
          type: 'string'
          type: 'bool'
          type: 'date'
          type: 'number'
        datatype: "array"
      $("#jqxgrid").jqxGrid({
          width: 850,
          showfilterrow: true,
          localization: loc,
          selectionmode: 'multiplecellsextended',
          updatefilterconditions: function(type, defaultconditions) {
            var stringcomparisonoperators = ['CONTAINS', 'DOES_NOT_CONTAIN', 'EMPTY', 'NOT_EMPTY'];
            var numericcomparisonoperators = ['EQUAL', 'NOT_EQUAL', 'NULL', 'NOT_NULL'];
            var datecomparisonoperators = ['LESS_THAN', 'GREATER_THAN'];
            var booleancomparisonoperators = ['EQUAL', 'NOT_EQUAL'];
            switch (type) {
              case 'stringfilter':
                return stringcomparisonoperators;
              case 'numericfilter':
                return numericcomparisonoperators;
              case 'datefilter':
                return datecomparisonoperators;
              case 'booleanfilter':
                return booleancomparisonoperators;
          columns: [{
            text: 'Name',
            columntype: 'textbox',
            filtertype: 'input',
            datafield: 'name',
            width: 215
            text: 'Product',
            filtertype: 'checkedlist',
            datafield: 'productname',
            width: 220
            text: 'Available',
            datafield: 'available',
            columntype: 'checkbox',
            filtertype: 'bool',
            width: 67
            text: 'Ship Date',
            datafield: 'date',
            filtertype: 'range',
            width: 210,
            cellsalign: 'right',
            cellsformat: 'd'
            text: 'Qty.',
            datafield: 'quantity',
            filtertype: 'number',
            cellsalign: 'right'
        .on('filter', function(event) {
          console.log(event);
          $('#console').append('<p>Filtred</p>');
    Also, here is prepared http://jsfiddle.net/SergioV/7mjs3e9u/
    As you can check, if change filter conditions in dropdowns, filter event fired for every selector, except numeric. This mean, that we can’t filter table with null values, for example
    Christopher
    Hi SergioV85,
    in order for your example to work properly, first you need to bind to the bindingcomplete event before the Grid’s initialization. Here is the example you provided with the needed corrections to make it work as expected:
    http://jsfiddle.net/Xr4LS/125/
    You can read more about how to add custom filtering to a grid, here:
    http://www.jqwidgets.com/jquery-widgets-documentation/documentation/jqxgrid/jquery-grid-filtering.htm
    Christopher
