jQuery UI Widgets Forums Grid CRUD using Grid
This topic contains 2 replies, has 2 voices, and was last updated by  zakstev 9 years, 3 months ago.
  • CRUD using Grid #79983
    zakstev
    hi Team,
    i ‘m a newbie working on a JSP project, I have a scenario where in i have to retrieve data from the database(MySQL) table i.e.(Item Code, Quantity, Rate Discount and Gross) columns in a Grid and user can Add, Edit and Delete records and saves back to the database from the Grid. Appreciate if you could send me a code sample.
    Thanks in advance.
    Zakstev
    CRUD using Grid #79996
    Hi Zakstev,
    Please refer to our help topic jqxGrid CRUD using JSP. We hope it is helpful to you.
    CRUD using Grid #80058
    zakstev
    It’s exactly as per my requirement…i think i made the right decision by purchasing jqwidgets…Thank you very much Dimitar…
