jQuery UI Widgets Forums Grid Cross Site Service call for JxGrid is not working
This topic contains 3 replies, has 3 voices, and was last updated by  ysut 9 years, 4 months ago.
  • abinjaik
    I have downloaded the sample asp.net code of jqxGRid in which it do “Paging , Sorting & Filtering” using a webservice(service.asmx) . In my scenario, My Service will hosted on other location / domain and I need to consume this service to display data on jqxgrid. I TRIED MAKING “JSONP” with remote service URL but it doesnt work. Giving an error message “Error:Jquery231312321312211… was not called” . Why this error? My code is as below
                //debugger;
                function buildQueryString(data) {
                    var str = '';
                    for (var prop in data) {
                        if (data.hasOwnProperty(prop)) {
                            str += prop + '=' + data[prop] + '&';
                    return str.substr(0, str.length - 1);
                var formatedData = '';
                var totalrecords = 0;
                //Getting the source data with ajax GET request
                var source = {
                    datatype: "jsonp",
                    { name: 'CompanyName' },
                    { name: 'ContactName' },
                    { name: 'ContactTitle' },
                    { name: 'City' },
                    { name: 'Country' },
                    { name: 'Address' }
                    sort: function () {
                    filter: function () {
                        var returnData = {};
                        data = data.d;
                        totalrecords = data.count;
                        returnData.totalrecords = data.count;
                        returnData.records = data.data;
                        return returnData;
                    type: 'GET',
                    sortcolumn: 'CompanyName',
                    sortdirection: 'asc',
                    formatdata: function (data) {
                        data.pagenum = data.pagenum || 0;
                        data.pagesize = data.pagesize || 10;
                        data.sortdatafield = data.sortdatafield || 'CompanyName';
                        data.sortorder = data.sortorder || 'asc';
                        data.filterscount = data.filterscount || 0;
                        formatedData = buildQueryString(data);
                        return formatedData;
                    url: 'http://localhost:4545/Service.asmx'
                                contentType: 'application/json; charset=utf-8',
                                    alert(error);
                $("#jqxgrid").jqxGrid({
                    virtualmode: true,
                    sorttogglestates: 1,
                    rendergridrows: function (args) {
                        return args.data;
                        { text: 'Company Name', dataField: 'CompanyName', width: 250 },
                        { text: 'Contact Name', dataField: 'ContactName', width: 150 },
                        { text: 'Contact Title', dataField: 'ContactTitle', width: 180 },
                        { text: 'Address', dataField: 'Address', width: 180 },
                        { text: 'City', dataField: 'City', width: 80 },
                        { text: 'Country', dataField: 'Country', width: 100 }
    Hi abinjaik,
    It looks like the Ajax call with JSONP to your service does not work for some reason which I think is not related to our widget. I would suggest you to look at some tutorials about implementing JSONP response in ASP .NET like that one: http://www.codeproject.com/Tips/631685/JSONP-in-ASP-NET-Web-API-Quick-Get-Started
    abinjaik
    Peter,
    But normal JSON request works well. Only JSONP have issues.
    ysut
    Any luck with this issue? Seem I am facing the same problem here. Please help and thanks
