This topic contains 1 reply, has 2 voices, and was last updated by  Stanislav 7 years, 4 months ago.
  • Copy issue with disabled jqxInput #98121
    gkushner
    You cannot copy text in a jqxInput when:
    1. It’s disabled
    2. You highlight from right-to-left
    3. You highlight all the way to the beginning position.
    4. There is a placeHolder property provided in the constructor
    It works without the placeHolder and other copying scenarios.
    Link to Fiddle
    NOTE: This happens in Chrome. It works fine in Edge and you cannot copy disabled fields in Firefox.
    Copy issue with disabled jqxInput #98125
    Stanislav
    Hello gkushner,
    In the tests I did, I got this results:
    1) I was able to copy the text
    2) Here I found something interesting, which you probably caught.
    If you use placeHolder it is very hard to copy the text, and you can only copy all of it. While using value, you can copy parts of the text if you want.
    Stanislav
