jQuery UI Widgets Forums Editors FileUpload Control not working
This topic contains 2 replies, has 2 voices, and was last updated by  anubis76 10 years, 2 months ago.
  • Control not working #67016
    anubis76
    Hi.
    I have tried the code in the examples to create the FileUpload widget. No matter how I try to set any properties, I just keep getting
    “uncaught exception: Invalid property: template”
    I am using the latest download of jqWidgets.
    My code is simple:
    Within the $(document).ready(function(){….
    $('#jqxFileUpload').jqxFileUpload({ browseTemplate: 'success', uploadTemplate: 'primary', cancelTemplate: 'danger', width: 300, uploadUrl: 'imageUpload.php', fileInputName: 'fileToUpload' });
    And in my HTML:
    <div id="jqxFileUpload"></div>
    Please tell me if I am missing something?
    Control not working #67058
    Hello anubis76,
    Are you sure you have updated all files to the latest version (3.7.0), including jqxbuttons.js? As you can see from the following demo: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxfileupload/javascript-file-upload-button-templates.htm?arctic, there are no issues on our side.
    Control not working #67085
    anubis76
    Hi Dimitar,
    Thank you for your reply. I re-checked everything and found the problem. I was using some of the script files from the previous jqWidgets as I had re-used code from a previous project that used the earlier version of jqWidgets. After replacing jqxbuttons.js from 3.7.0, it started working! Now I feel dumb.
    Thanks again 🙂
