jQuery UI Widgets › Forums › Navigation › Tabs › content in div becoming non editable mode by using jqwidgets , jqtabs
This topic contains 1 reply, has 2 voices, and was last updated by Martin 6 years, 5 months ago.
October 29, 2018 at 12:31 pm content in div becoming non editable mode by using jqwidgets , jqtabs #102552
Trying to implement jqtabs with jqtree . scenario when we try to click on the node of the tree new tab will be opened with the content .
New tab is created in the last with content but it is not editable . not sure about the behaviour of the tree with tabs combo . My Code goes as follows :
<aside class="right-sidebarmodi"> <div id='jqxTree'> <ul> <li item-expanded='true'>Transaction Data <ul> <li id="oo">oo</li> <li id="fc">fc</li> <li id="pc">pc</li> </ul> </li> </ul> </div> </aside> <div id='jqxWidget'> <div style='float: left;'> <div id='jqxTabs'> <ul style='margin-left: 10px;'> </ul> <div id='oo1' > <ui:include src="../../dsmod/transaction/1.xhtml" /> </div> <div id='fc1' >Tab 2</div> <div id='pc1' >Tab 3</div> </div> </div> </div>
And my script is as follows :
<script type="text/javascript"> $(document).ready(function () { // Create jqxTree $("#jqxTabs").css('visibility', 'hidden'); $('#jqxTree').jqxTree({ height: '800px', width: '245px' }); $('#jqxTree').bind('select', function (event) { var htmlElement = event.args.element; var item = $('#jqxTree').jqxTree('getItem', htmlElement); var position; var tabsCount = $("#jqxTabs").jqxTabs('length'); // alert(tabsCount); for (var i = 0; i < tabsCount; i++) { var tabTitle = $("#jqxTabs").jqxTabs('getTitleAt', i); if (tabTitle == item.label) { position = i; break; }; }; alert(item.label); $("#jqxTabs").css('visibility', 'visible'); $('#jqxTabs').jqxTabs('removeAt', position); $('#jqxTabs').jqxTabs('addLast', item.label, $("#"+item.id+"1").html() ); $('#jqxTabs').jqxTabs('ensureVisible', -1); }); }); </script> <script type="text/javascript"> $(document).ready(function () { $('#jqxTabs').jqxTabs({ height: 800, width: 1200 , showCloseButtons: true}); }); </script>
Did any one tried with tree with tabs . is this the same behaviour or any work around for this .
October 30, 2018 at 10:18 am content in div becoming non editable mode by using jqwidgets , jqtabs #102561Hello bhanu.k,
Yes, this is the functionality of jqxTabs.
The content of the tabs can be updated using thesetContentAt
method.
Here is an Example of it.Best Regards,
MartinjQWidgets Team
